No Boost
XRT Man
  • Member For: 16y 4m 16d
hey guys I was just wondering if any one has had the problem where there car stops making boost it still idles fine and runs fine but its not realy making any boost
  • iTs alL DaRDy........
  • Member For: 17y 4m 28d
sounds weird? hopefull nothing to serious
maybe wastegate stuck open?
or Induction pipe come off somewhere?
is the ECU light on?
dont really know mate'
id check the pipework etc first
  • Member For: 18y 2m 19d
are you getting a sound which is like air escaping from the system? first check all the clamps around the cross over and turbo piping... then check if you can for the turbo bolts missing (yes it happens they come loose and fall off!) thennn if all else fails I guess it could also be your turbo manifold which has come loose (this happened to me) good luck
mark.
if it was a Expensive Daewoo he would be more likely asking
"my car drives like a piece of crap, I put my foot down and nothing happens, and my clutch and gear box feel like sh*t and my center console is fuking ugly, has anyone else had this problem?"
hi Dags
  • Member For: 17y 9m 17d
WHEN you say no boost ,do you mean its down on power or have no power .. ,if this is the case ,it could have a blocked cat ....happen to mine ,ran fine ,drove fine ,but as soon as you go to give it some not alot would happen..
cheers
  • 1 year later...
  • Member For: 19y 9m 30d
Yep currently having the same problem, though at first it would make some boost, slowly up to 6psi at max rpm. Car is tuned to 12psi with standard actuator. I checked manifold bolts, all hoses and clamps and even replaced the wastegate control solenoid. Then by coincidence the dump pipe to turbo bolts came loose so tightened them. Now no boost at all.
I had my local Ford service take a look because I spotted a turbo housing bolt loose on the exhaust side, which I couldn't get to. They tightend that and also found a turbo mounting bolt missing. But still no boost, so they took the dump pipe off and found the wastegate stuck open. Will be taking somewhere else to fix that as all they could offer is send the turbo away for a rebuild.
So a few issues all at once, but main one is the wastegate stuck open for me. Cheers.
Ben
Edited by benjam
