Whats The Best For Interior?
NFORCD
  • Force Fed Fords
  • Member For: 16y 4m 19d
Hi everyone, Just wondering with the detail you guys use with your dash and stuff... I used a Armor all one and after a few times of using it, the colour started to fade and looked pretty bad... Luckily this was on my old car, and now dont want to go through that same thing. Any recommendations with the products. I knoe meguiars is one of the top of the range but how about autoglym??? Would much appreciate it...
  • Mmmmm......BOOST
  • Member For: 17y 10m 3d
haven't tried autoglm, I use meguires dash and trim foam in the pressure can it always comes up nice
sun is your enemy when it comes to colour fade make sure you use a sun shield in the windscreen whenever you park out side
  • Force Fed Fords
Yeh autoglym is top quality stuff but not sure how well it would work. Yeh I might just stick to the meguiars, as %90 of the products im starting use is that...
  • Member For: 18y 8m 11d
Anything that is water based, not solvent based and that is silicone free, will be fine
The water based ones will be usually a matte or satin finish and the solvent/silicone based will be glossy
The solvent dry rots rubber and vinyl and can affect plastics over time
My personal favourite is Driven to Perfection VRL, a creamy water based product that absorbs into leather, vinyl and rubber and that does not leave any residue to wipe off
Wipe on, walk away
For best results always clean your interior dash, console, door skins and seats with a non acidic, PH neutral or low alkaline silicone/solvent free cleaner
Check meguiars MSDS sheets on their website if you want to know which ones are solvent and silicone free
Most stuff is fine, just keep clear of some high gloss products (silicone-solvents) that are not dry to the touch and that attract dust
The cleaner I use every day at my shop is this one (gallons of course)
http://www.autoprodetailproducts.com/product/Soft
