bambis Member 18 Member For: 16y 2m 29d Gender: Male Location: Sydney - Kellyville Posted 08/10/08 10:20 AM Share Posted 08/10/08 10:20 AM (edited) Hi guys,I recently purchased an 2004 BA XR6T, and love everything about it. I discovered these forums and have found it to be awesome so far. Anyhow, I figured this would belong in this forums so here goes.The car drives real nice as long as my foot isnt holding the pedal down. I can go real close and all is fine, but as soon as I really put the pedal down all the way something worrying happens. As my revs reach about 4000 in either 1st or 2nd and the turbo is reaching its peak, I get a horrible stutter or shudder effect and slight back firing. im running the 4speed auto and as this happens the gears will not change, I have to shift up using the sequentials.. It feels like a rev limiter and/or the traction control. after some experimenting with the traction control off, the problem is slightly less depressing, but definately still there. It really feels like an old motor bike when u give it and it floods slightly. I need to take my foot off for it to change gears, and if I use the squential then I have to change gear early as to avoid the shutter. I would really appreciate any input atm guys, money is an issue since I now have a loan to pay off, and my 1st thought is obviously to take it down for a tune, but some opinions here may go further. I have read of other people here with similar issues, and im hoping that maybe one of you can shed some light on a prblem that seems quite common.the car, as far as I know, is completely stock except for a K&N. the turbo seems strangly loud also, so maybe the previous owner had an aftermarket blowoff valve installed?anyway thanks in advance!bambis Edited 08/10/08 10:21 AM by bambis Link to comment Share on other sites More sharing options...
xr6turboman Donating Members 588 Member For: 16y 8m 16d Gender: Male Location: New Zealand, Palmerston North Posted 08/10/08 08:08 PM Share Posted 08/10/08 08:08 PM (edited) heya, might be spark plugs? try taking them out and having a look at em some other guys will have a better idea I guessand with K&N filter it should be pretty loud I put 1 in and made a big difference - but if you want to be on the safe side check the hoses around the crossover and the turbo for leaks and sh*t - I was pretty worried about mine a while ago until I asked and they said do that. Sounds good though don't it lol Edited 08/10/08 08:10 PM by xr6turboman Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 8m 1d Gender: Male Location: central coast Posted 08/10/08 09:35 PM Share Posted 08/10/08 09:35 PM plugs and coil packs would be a good place to start lookin ,last time I had one die the car would run to 160rwkw fine then start losing power.try reseting the tps to, hold peddle flat to floor and crank car over ,it should not start but will reset your throttle position Link to comment Share on other sites More sharing options...
ICJLSY Member 38 Member For: 18y 11m 15d Posted 08/10/08 10:22 PM Share Posted 08/10/08 10:22 PM "horrible stutter or shudder effect and slight back firingIt feels like a rev limiter and/or the traction control. after some experimenting with the traction control off, the problem is slightly less depressing, but definately still there. It really feels like an old motor bike when u give it and it floods slightly. I need to take my foot off for it to change gears, and if I use the squential then I have to change gear early as to avoid the shutter"I had the same problem as this just last week..I thought it was my custom tune that I had done. wen I took it bak to b chekd out, they found the fuel pump wasnt installed properly and that the fuel line was split. they changed this and the car runs awesome again. Link to comment Share on other sites More sharing options...
bambis Member 18 Member For: 16y 2m 29d Gender: Male Location: Sydney - Kellyville Posted 08/10/08 11:23 PM Author Share Posted 08/10/08 11:23 PM thanks for the fast replys guys, im at work atm, but as soon as I get home ill check what u mentioned, so its obvious that it could be the coils, since they are the cause of half of everyones problems. but has anyone ver had a clash with the traction control? or is that a seperate system and I shouldnt worry about it? cheers.bambis Link to comment Share on other sites More sharing options...
millers Member 113 Member For: 16y 6m 28d Posted 08/10/08 11:32 PM Share Posted 08/10/08 11:32 PM but has anyone ver had a clash with the traction control? or is that a seperate system and I shouldnt worry about it?me and traction control arent the best of friends when TCS comes on the orange light on the dash will flash and it will sound like its missing Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 8m 1d Gender: Male Location: central coast Posted 08/10/08 11:40 PM Share Posted 08/10/08 11:40 PM traction control is a dirty word Link to comment Share on other sites More sharing options...
bambis Member 18 Member For: 16y 2m 29d Gender: Male Location: Sydney - Kellyville Posted 09/10/08 01:35 AM Author Share Posted 09/10/08 01:35 AM when TCS comes on the orange light on the dash will flash and it will sound like its missingyup, that's exactely like my car seems to be doing at max throttle.so reseting the throttle is simply achieved by holding it down then trying to start the car? what could have possibly caused it to be incorrect? what kind of noise can I expect from a stock BOV? from what I can tell it is stock, but the noise definately doesnt seem to be. I get a loud spool noise and a flutter after I release the throttle. do you guys get a similar sound from your BOV's? bambis Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 8m 1d Gender: Male Location: central coast Posted 09/10/08 02:25 AM Share Posted 09/10/08 02:25 AM hold flat and crank for 10-15 sec then turn off and start normally , Link to comment Share on other sites More sharing options...
iTec TEAM BA Donating Members 1,755 Member For: 20y 21d Gender: Male Location: North of The Bridge Posted 09/10/08 03:43 AM Share Posted 09/10/08 03:43 AM It sounds to me more like your fuel pump has shat itself and the engine is being starved for fuel... when mine collapsed it was doing exactly the same thing, you could drive around fine on 3/4 throttle and still reach 6000prm, but if you hit full throttle it would hit 4000rpm and start splattering and backfiring... take your foot off the pedal and it would run rough for a few seconds till the pump caught up.best bet is to get it put on a dyno and have it checked out Link to comment Share on other sites More sharing options...
