Tree Monkey Member 685 Member For: 17y 5m 23d Gender: Male Location: brisvagas / Manly Posted 08/10/08 03:56 AM Share Posted 08/10/08 03:56 AM if you are runing the plenum you have done the flapper and actuator? Put a 4" dump and cat then a twin 2.5" setup on and you should be pulling 350+rwkw on 13lb of boost. Link to comment https://www.fordxr6turbo.com/forum/topic/50462-tuned-311kwrw/page/2/#findComment-746401 Share on other sites More sharing options...
NeedmorePower Member 192 Member For: 19y 6m 4d Posted 08/10/08 05:23 AM Author Share Posted 08/10/08 05:23 AM thanks for the replies guys yes the exhuast must be a problem.its got the standed dumb pipe. guttedred cat 3.5 in through and the 2 mufflers are 3 inch.no ive still got the standed actuator. nizpro have not commented about that as the boost comes on good and decent . but yes I need to change that in the future.ive had this done 3years ago back then we didnt know as much as we all know now, but when I did get the exhuast done from memory I dont think it over boosted, if not at all b4 it got tuned.? Link to comment https://www.fordxr6turbo.com/forum/topic/50462-tuned-311kwrw/page/2/#findComment-746439 Share on other sites More sharing options...
Dirty32 Legendary member!! Donating Members 1,739 Member For: 18y 4m 10d Gender: Male Location: Dianella, West Oz Posted 08/10/08 05:46 AM Share Posted 08/10/08 05:46 AM So if im reading this correctly, You had the exhaust done 3 years ago and only got a tune recently?If that's the case, then that would indicate that gutting your cat or doing whatever you have had done to your exhaust, the flow of your exhaust has not really changed from factory... If there was a difference in flow and less restriction than the stock exhaust system, given a bootful you should overboost.This would effectively mean that your exhaust (poorly gutted cat or small mufflers) is whats restricting your car from making more power!Someone correct me if im wrong... Link to comment https://www.fordxr6turbo.com/forum/topic/50462-tuned-311kwrw/page/2/#findComment-746447 Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 11m 9d Gender: Male Posted 08/10/08 06:03 AM Share Posted 08/10/08 06:03 AM that sounds right to me. usually a gutted cat would make a car overboost on the stock tune! Link to comment https://www.fordxr6turbo.com/forum/topic/50462-tuned-311kwrw/page/2/#findComment-746452 Share on other sites More sharing options...
NeedmorePower Member 192 Member For: 19y 6m 4d Posted 08/10/08 06:07 AM Author Share Posted 08/10/08 06:07 AM thanks for the replies again guys as im not posting complaints about nizpro as they tried for 2 and half hours on the car, the problem is the car and ill get around this I hope. has any1 been in the same boat as me for example a bad exhuast system or bad mufflers and not producing the proper power the car may have?? Link to comment https://www.fordxr6turbo.com/forum/topic/50462-tuned-311kwrw/page/2/#findComment-746455 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 12d Gender: Male Location: Sydney NSW Posted 08/10/08 06:07 AM Share Posted 08/10/08 06:07 AM He's just recently fitted my cooler & (plaz)plenum kit and was in to get it RE- tuned to suit.The exhaust, due to its age posible has rusted or colapsed mufflers, which would be holding it back alot. So from all indications its an airflow issue out of the motor, the main pipes look good, 3.5inch, but the muffs look restrictive and old school.There could be holes in the joins/welds and seams which can have a huge impact on flow.If it was mine, Id chop out the centre muff and replace the rear for a straight through style muff... hit the dyno and see how it looks. Link to comment https://www.fordxr6turbo.com/forum/topic/50462-tuned-311kwrw/page/2/#findComment-746456 Share on other sites More sharing options...
NeedmorePower Member 192 Member For: 19y 6m 4d Posted 08/10/08 06:10 AM Author Share Posted 08/10/08 06:10 AM no the car got retuned as I recieved rapids plenium and cooler and intake. b4 this I had the car tuned at 287kwrw with the guttered cat. Link to comment https://www.fordxr6turbo.com/forum/topic/50462-tuned-311kwrw/page/2/#findComment-746458 Share on other sites More sharing options...
dule Donating Members 1,180 Member For: 18y 1m 16d Gender: Male Location: Sydney Posted 08/10/08 06:28 AM Share Posted 08/10/08 06:28 AM Just unbolt the motherf*cker on the first joint after the cat (not sure where that is, hopefully before the first muffler) and throw it on the dyno, then you'll know for sure if it's the exhaust. Doesn't get much more high flow than that, it sounds nice too . Link to comment https://www.fordxr6turbo.com/forum/topic/50462-tuned-311kwrw/page/2/#findComment-746466 Share on other sites More sharing options...
Wingnut Member 573 Member For: 16y 9m 28d Gender: Male Posted 08/10/08 07:52 AM Share Posted 08/10/08 07:52 AM Your power reading isnt really low mate, but I would think it would be the small dump you are using. I only use a 3" front to back but it must be a good bit of kit as I make a little more than 311rwkw. I also had it tuned by Nizpro, run a Nizpro plenum and AVO cooler which seem to all work well together. Link to comment https://www.fordxr6turbo.com/forum/topic/50462-tuned-311kwrw/page/2/#findComment-746517 Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 6m 2d Gender: Male Location: Melbourne Posted 08/10/08 09:45 AM Share Posted 08/10/08 09:45 AM How did you find the place? Link to comment https://www.fordxr6turbo.com/forum/topic/50462-tuned-311kwrw/page/2/#findComment-746579 Share on other sites More sharing options...
