  • Every Mod's Favourite Member
  • Member For: 17y 1m 29d
I was just wondering if the engine light was one of the lovely side-effects of a flash tune?
I noticed mine was on today and can't say I have ever seen it before. I did a quick read-up and all it mentions is that the car is now operating outside of emissions standards. Has this light been on the whole 6 months I've had my car (and I'm a blind *beep*) or is it an indicator that I should get it checked out?
  • Member For: 18y 13d
nope is it still under ford warranty is so flash back to standard and see if the light comes back on , if no other mods besides flash tune ,
Edited by trevs
Nah, I'm talking about a flash tune on a mildly modded car.
EDIT* Injectors, Debung, CAI.
Edited by Grudgee
  • Forged Member
  • Member For: 18y 2m 27d
Check your cat grudgee, it could have collapsed causing the emissions light to come on, you'll notice if it gets worse as the performance may start to suffer higher in the rev range
  • Member For: 21y 3m 3d
faulty o2 sensor also causes the engine light to come on.... I had a blown o2 sensor fuse... which was caused by me fitting the heat shield and in the process shorting the oo2 sensor wire which caused the 02 sensor fuse to blow... took me a a while to figure this out
  • Member For: 18y 7m 11d
Hey Grudgee
Engine light is a problem that sometimes occures after flash tune. If you have a custom tune take it back to your tuner so they can get rid of the light ,if a generic tune then you may have to put up with it.
To check if it is in the tune ,flash it back to standard, start the engine and see if the light goes away if it is still there take it to a dealer to check that something is not wrong with your cat.
Good luck
PS may not start in standard mode with your bigger injectors so go back to the second tune and try :buttrock:
  • Member For: 18y 4m 6d
Wouldn't be a BF by any chance? Mine started doing that after my exhaust was fitted, has to do with the second O2 sensor reading emissions that are out of normal operating range. I just clear the fault code using my gauges, comes back after a big spurt.
