gilto Member 218 Member For: 17y 10m 22d Gender: Male Posted 05/10/08 05:29 AM Share Posted 05/10/08 05:29 AM Hi guys,Ok so I have this GFB Hybrid BOV which is like a 3-in-1 valve. You can have it full-atmo, 50/50 or fully plumbed-back.I have experimented with all 3. BTW mine is an auto running 15psi...When revs are high and the foot comes off it's fine....gives a loud and snappy WHOOOOOOSH!Problem (for me) is when the revs are low.....say between 2000 and 3000 under light acceleration and you back off it give the TU TU TU TU TU TU sound. It was cool at first but it's becoming annoying. My car is a sleeper and under normal driving acceleration (2000 - 3000rpm I don't want any noise.I only want noise when I am hammering it.....not driving to the shops and back if you know what I mean.....I want the TU TU TU TU TU noise gone....Is there something I can do regards spring etc? I wound the adjustable spring to the softest level and it still does the TU TU TU TU.... (When I put on the twin trumpets to full atmo it was SO LOUD!!!! haha pretty funny!) Link to comment https://www.fordxr6turbo.com/forum/topic/50396-gfb-bov/ Share on other sites More sharing options...
benjam Member 137 Member For: 20y 1m 18d Location: Sydney NSW Posted 05/10/08 08:32 AM Share Posted 05/10/08 08:32 AM How does it sound at full plumb back? I have the GFB stealth and have been playing around with it for awhile. You should have the spring on the softest setting. Some cars that have an AFM, softest setting can cause problems like exhaust back fire, but XR6T's don't use one and softest is fine. If you increase the spring pressure your TU TU noise will be even more. The TU TU TU TU TU noise at low revs, is the air moslty backing up and causing cavitation on the turbo impeller blades. It isn't escaping the BOV fast enough. I was getting the same sound on mine with a harder spring setting. You are probably still getting some TU TU TU etc at full atmo, but the Pssshhh noise drowns it out.So you could perhaps get a softer spring, GFB make them. But the main problem is that the standard crossover connections for the BOV are tiny and the increased airflow with more boost just is too much. I've been considering modifying the crossover and using something like a 35-38mm weld on adapter and piping to suit, or another crossover like and AVO one (if they answer my PM hehe). My GFB on full atmo goes Pshhhh shhh shhhh shhhh and lasts for about 1.5 secs, where I want to air to come out much faster and short period like you hear WRXs and EVOs. They have BOVs that bolt on directly to the intake so have bigger adapers standard, because they run more boost standard.Or you could get Plazmaman piping and ask for bigger adapters to suit. Or you could get a turbosmart adapter, but then you can't have plumbback as the BOV connects near the turbo on that one. I've been looking for something that allows my BOV to sit in the standard location just so it doesn't stick out like the proverbial.Ben Link to comment https://www.fordxr6turbo.com/forum/topic/50396-gfb-bov/#findComment-745081 Share on other sites More sharing options...
turbo.vixen Hey guys, Tab is here... Oh i feel sick Lifetime Members 8,459 Member For: 16y 11m 29d Gender: Male Location: sunshine coast Posted 05/10/08 08:42 AM Share Posted 05/10/08 08:42 AM im no mechanic but dont they have a adjuster screw for harder or softer, maybe its set to soft and needs to be tightened? Link to comment https://www.fordxr6turbo.com/forum/topic/50396-gfb-bov/#findComment-745087 Share on other sites More sharing options...
gilto Member 218 Member For: 17y 10m 22d Gender: Male Posted 06/10/08 04:45 AM Author Share Posted 06/10/08 04:45 AM Thanks guys,Yeah that makes sense...maybe I should try the softer spring first and then if it still does it have my connector enlarged. I have plazmaman piping already but the exit weld on the pipe is the same size as standard I think?Shouldn't be too much of a problem for them to take it off, cut a hole and put a larger diameter weld on there.....I'll let you know how I go with the soft spring..... Link to comment https://www.fordxr6turbo.com/forum/topic/50396-gfb-bov/#findComment-745444 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 11m 26d Gender: Male Location: Melbourne Posted 06/10/08 07:02 AM Share Posted 06/10/08 07:02 AM On the GFB I think you can tighten the spring so it will only vent under high boost but I don't think this will get rid of the surging under low boost. Link to comment https://www.fordxr6turbo.com/forum/topic/50396-gfb-bov/#findComment-745505 Share on other sites More sharing options...
Shaky Bones Member 6 Member For: 16y 2m 26d Posted 25/02/09 01:47 PM Share Posted 25/02/09 01:47 PM well the tu tu tu tu is compressor surge so I wouldn't want much of it at high revs and boost Link to comment https://www.fordxr6turbo.com/forum/topic/50396-gfb-bov/#findComment-831093 Share on other sites More sharing options...
Guest Guests Posted 26/02/09 01:55 AM Share Posted 26/02/09 01:55 AM What airbox setup are you running? If the intake pipe is relocated to the standard battery position, you'll have to live with the tu tu tu sound... Or decrease boost. Link to comment https://www.fordxr6turbo.com/forum/topic/50396-gfb-bov/#findComment-831199 Share on other sites More sharing options...
