  • Member For: 19y 9m 20d
  pulonium said:
- Increased the pressure in the transmission lines by 10%
you cannot alter the transmissions line presure on a ZF, you can however alter the torque table which has a effect in ramp speed of the gear change
So this may have helped your issue
  Quote
- Changed the 1st gear shift point in ECU
you cannot chagne the 1st gear shift point in the ECU for the ZF, this table is only valid for the 4 speed automatic transmission (if fitted).
The ZF has its own internal shift presure ramp tables and shifting tables
  Quote
- Replaced auto transmission filter and oil with a premium synthetic oil
This is more likely whats fixed your problem.
  • Member For: 18y 1m 10d
I dont know whats worse being told by your tuner he changed all of the above when he didnt or paying for it even though it cant be done :blush:
  • Member For: 22y 4m 4d
This is more than likely due to loss of traction...
When power is raised the standard DSC will not keep up...
  • Member For: 16y 8m 16d
Well the tuner is a forum sp0nsor, I'd like to think they know what they're doing, maybe they dumbed down telling me what they did for my benefit (being mechanically illiterate) or I misunderstood them, but either way it's working fine now so I'm happy!
I wasn't trying to mislead anyone, a couple of people were having the same problem and wanted to know what I did to fix it.
Edited by pulonium
I turned off the traction control (I assume that disables the DSC) and it still did it without fail....
What state are you in?
Traction Control turned off = loss of traction (as the car looses traction at the top end the revs peg into redline)..
