BlueOvalPrint Member 15 Member For: 19y 3m 12d Posted 30/09/08 04:44 AM Share Posted 30/09/08 04:44 AM Hi, I've got a question about brake bleeding procedures for my beloved T. I do all work on my car myself and have done brakes on lots of cars before, but I want to clarify the right way to bleed the T - and find out why the Ford manual sets out a different process to most cars.I was taught the following: with 2 people, one pumps the pedal 3-5 times then holds it down while the second person then loosens the bleed valve which pushes the air bubbles/dirty fluid into a tube connected to a waste container. They then do up the valve, then repeat the pump/bleed process about 4 times per wheel. Or with one person and a one-way bleed tube, loosen the valve, pump the pedal about 6 times, then lock off the bleeder and repeat for the other wheels.However, according to Ford's BA Falcon manual (sorry, can't find the link atm but it is on this site), the procedure is connect the tube, loosen the bleeder, push the pedal fully down once then close the bleeder. Wait 5 seconds then repeat as required.So..why the difference? I recall when I had a (blush) '99 Magna, the Haynes manual advised the engine (and therefore the ABS system) had to be running during the process. Does eveyone use the Ford technique or is the "old" style still ok?Cheers, Dean Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 11m 25d Gender: Male Location: SW Sydney Posted 30/09/08 05:27 AM Share Posted 30/09/08 05:27 AM Ford style is ok mate, it worked for me when I did a brake upgrade (calipers and discs)Just remember to start with the rear passenger side, then rear driver, then passenger front, then the driver front. Link to comment Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 5m 26d Gender: Male Location: Newcastle Posted 30/09/08 08:43 AM Share Posted 30/09/08 08:43 AM Dean,Your method sounds like the usual way I've had it done on my previous BA and also other non ford vehicles. I'd stick with it I reckon.Benny. Link to comment Share on other sites More sharing options...
samzbob Banned 3 Member For: 16y 5m 1d Posted 30/09/08 08:52 AM Share Posted 30/09/08 08:52 AM Ford style is ok mate, it worked for me when I did a brake upgrade (calipers and discs)Just remember to start with the rear passenger side, then rear driver, then passenger front, then the driver front.Being a Turbo (which has traction control) yes that is right, just a note incase someone does a BA XR6 or XT without traction control, the RR wheel usually gets done first, as the brake pipe goes to the left hand hose, then splits off to the right on non traction control vehicles. Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 4m 26d Gender: Male Location: Southern Highlands NSW Posted 30/09/08 09:22 AM Share Posted 30/09/08 09:22 AM Bled plenty of brakes here. Most recent were a HD Expensive Daewoo X2 my old man is doing up and they were done the "normal" way Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m 4d Gender: Male Location: central coast Posted 30/09/08 10:28 PM Share Posted 30/09/08 10:28 PM I have done front only on mine when I changed discs and it was fine ,the front and rear are seperate systems ,as long as you don't let the fluid get to low you can do the front without doin the back Link to comment Share on other sites More sharing options...
jj1947 Member 12 Member For: 14y 8m 2d Posted 01/11/10 01:08 AM Share Posted 01/11/10 01:08 AM Dean,Your method sounds like the usual way I've had it done on my previous BA and also other non ford vehicles. I'd stick with it I reckon.Benny. What if you brake the hydraulic line at the master cylinder such as a replacement, I read somewhere that if you brake the line before the ABS modulater than normal bleeding wont get the air out and needs special bleeding procedures does anybody know anything about this Link to comment Share on other sites More sharing options...
xr6greg Member 73 Member For: 16y 7m 11d Posted 01/11/10 01:14 AM Share Posted 01/11/10 01:14 AM (edited) Gravity bleed. Sit the whole car on a hoist, axle stands (purely to give you a bit of room. Crack open all the nipples and let the fluid 'bleed' through the system. Takes a while, half hour or longer, to do it properly. Gets messy as you can imagine. Edited 01/11/10 03:49 AM by RHR No need to quote above post. USE FAST REPLY Link to comment Share on other sites More sharing options...
Guest XR09 Guests Posted 01/11/10 02:21 AM Share Posted 01/11/10 02:21 AM The old way works fine. If it doesn't then the gravity way is the go. Just get some air line from a fish tank filter. This fits over the bleeders great. And 4 empty bottles. Like a 330ml coke bottle. Keep a good eye on the brake fluid res. And make sure it does not drain out completely.Use some good fluid like Penrite Sin or equivalent. Link to comment Share on other sites More sharing options...
Smoke them tyres Member 557 Member For: 17y 1m 10d Gender: Male Location: Brisbane Posted 01/11/10 10:33 AM Share Posted 01/11/10 10:33 AM (edited) Get yourself one of these:from:http://www.mcas.com.au/_products.php?subcategory=37&line=6They work brilliantly and save the bleeder screw threads and hex from the constant tightening/loosening. I bled all 4 brakes in mine in under an hour on my own. All you do for each brake is attach the bleeder with the outlet hose higher than the nipple and into a container, loosen the nipple and pump the brake pedal. The check valve in the tool will do the job of flow control for you.I would also recommend getting a proper thick wall brake nipple spanner as once rounded, they're . Edited 01/11/10 10:40 AM by Smoke them tyres Link to comment Share on other sites More sharing options...
