  • It's not a MKI!
  • Member For: 16y 11m 27d
  Dillz said:
Best thing about the FG's is you could fit a big arse turbosmart dual port on the factory plumbing easy as. Then she'll be LOUD.
On the contrary. You will get a loud pssssh from your turbosmart BOV, but there will be minimal 'dose' noise.
If you block the atmospheric port on the turbosmart you will slightly here the 'dose' noise.
If you completely remove the BOV and blank off all the ports you get a much louder 'dose' noise.
Been there, tried all the different combinations with the turbosmart BOV and factory components.
Loudest psssh was with the turbosmart, loudest 'dose' without any BOV.
  • Replies 32
Posted Images
  • Member For: 16y 8m 9d
Got a Hi Flow Pod filter Kit put on mine K&N with pipng and mounted a seal box around the filter for 200$ and fitted for free from Top Gear Performance in Queensland breaths heaps better sounds good. But the only way your gona get direct Ait Flow is by taking the the fog lamps out because the hole is right under the filter box when you take out, got an extra 9Kw out of it. Its worth it.
  • It's not a MKI!
9kW isn't bad. Is this on an FG though?
