axr-jet Donating Members 316 Member For: 20y 9m 28d Gender: Male Location: Melbourne Sth/East Posted 28/09/08 02:21 AM Share Posted 28/09/08 02:21 AM I have a BF MKII F6 and I am looking for 350 Rwkws what gear do I need, I have got so far 60lb injectors,Xforce exhaust with 4in dump,process west stage 2 cooler and a flash box,will I need a bigger fuel pump as for what I have seen on here a lot of people go that way, any more help would be great?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/50159-350-rwkws/ Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 9d Gender: Male Location: SW Sydney Posted 28/09/08 02:36 AM Share Posted 28/09/08 02:36 AM Yeah mate, something like the PW Surge tank and 044 set0up will do just fine, then get the turbo modified and a 12psi actuator fitted. With a retune this should net you around the 350 mark. Sounds easy huh?! Link to comment https://www.fordxr6turbo.com/forum/topic/50159-350-rwkws/#findComment-741440 Share on other sites More sharing options...
axr-jet Donating Members 316 Member For: 20y 9m 28d Gender: Male Location: Melbourne Sth/East Posted 29/09/08 03:20 AM Author Share Posted 29/09/08 03:20 AM Cheer's Link to comment https://www.fordxr6turbo.com/forum/topic/50159-350-rwkws/#findComment-741907 Share on other sites More sharing options...
xrglen Member 12 Member For: 16y 8m 9d Posted 07/10/08 10:29 AM Share Posted 07/10/08 10:29 AM axr-jet said: I have a BF MKII F6 and I am looking for 350 Rwkws what gear do I need, I have got so far 60lb injectors,Xforce exhaust with 4in dump,process west stage 2 cooler and a flash box,will I need a bigger fuel pump as for what I have seen on here a lot of people go that way, any more help would be great?Cheershi, for your 350rwkw you will need a bigger cat than the x-force one. they only flow about 300rwkw.. I use a 4" dump with a 4 bolt 4" flange into a 5" cat.. I also use a walbro gss294 or gss341/342 fuel pump kit..the std pump can only take about 320rwkw.. you will get close to 350rwkw but the inlet plenum is the biggest problem from here on..you could try a 12mm inlet plenum spacer to increase the inlet volume by about 10%.....cheers Link to comment https://www.fordxr6turbo.com/forum/topic/50159-350-rwkws/#findComment-746169 Share on other sites More sharing options...
qik1 Silver Donating Members 2,720 Member For: 17y 1m 5d Gender: Male Location: Loitering in SEQ Posted 07/10/08 10:43 AM Share Posted 07/10/08 10:43 AM not quite right mate theres quite a few blokes here running the x force cat & system seeing upwards of 400rwkw including myself. as for the plenum its not necassary at that point. cant hurt but not neccassary. for a safe 350 look at injectors, fuel pump (044 wll do it), induction & I/C combo, wastegate & actuator upgrade, exhaust incl cat & tune. someone like rapid systems or process west can put together good packages that will get you started. depending on your transmission & clutch that may become an issue at that point. john Link to comment https://www.fordxr6turbo.com/forum/topic/50159-350-rwkws/#findComment-746175 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 2m 23d Gender: Male Location: nsw Posted 08/10/08 05:56 AM Share Posted 08/10/08 05:56 AM valve springs. oil pump gears. Link to comment https://www.fordxr6turbo.com/forum/topic/50159-350-rwkws/#findComment-746451 Share on other sites More sharing options...
strik9 Banned 146 Member For: 18y 1m 8d Gender: Male Location: AUSTRALIA Posted 09/10/08 02:20 AM Share Posted 09/10/08 02:20 AM the most important thing of all.............. a decent shop that know what they are doing Link to comment https://www.fordxr6turbo.com/forum/topic/50159-350-rwkws/#findComment-746824 Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 10m 24d Gender: Male Location: Victoria Posted 10/10/08 08:33 AM Share Posted 10/10/08 08:33 AM (edited) qik1 said: not quite right mate theres quite a few blokes here running the x force cat & system seeing upwards of 400rwkw including myself. as for the plenum its not necassary at that point. cant hurt but not neccassary. for a safe 350 look at injectors, fuel pump (044 wll do it), induction & I/C combo, wastegate & actuator upgrade, exhaust incl cat & tune. someone like rapid systems or process west can put together good packages that will get you started. depending on your transmission & clutch that may become an issue at that point. john I have an XFORCE cat and have 335rwkw... So, I doubt the cat will hold you back.You need a 12psi actuator to hold around 15-17psi... Ported wastegate and larger flapper a good idea... But you have most things to get you running... Oh, and does the intercooler kit have an upgraded air intake, as you will need to remove all of the piping etc...If it is a Phoon, you dont need bottom end done, valve springs or clutch as they run a twin plate... and if its man, it will be a T56 so that is fine... Edited 10/10/08 08:36 AM by turboworm Link to comment https://www.fordxr6turbo.com/forum/topic/50159-350-rwkws/#findComment-747535 Share on other sites More sharing options...
axr-jet Donating Members 316 Member For: 20y 9m 28d Gender: Male Location: Melbourne Sth/East Posted 13/10/08 04:23 AM Author Share Posted 13/10/08 04:23 AM Thank's guy's, yeah looking at getting Mick from Pit Lane to do the Tune Ect for me as I have spoke to him before and bort a Flash Box from him. What would be better Process West full Intake System or Rapid Systems V4 or V4.5?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/50159-350-rwkws/#findComment-748693 Share on other sites More sharing options...
