Azzman460 Azzman Member 223 Member For: 16y 6m 8d Gender: Male Location: Melbourne Posted 24/09/08 01:12 AM Share Posted 24/09/08 01:12 AM G'day guys. I'm building a turbo motor with forged internals, once I get this going I will be running it with an F6 fuel pump and F6 Injectors on standard boost to run the motor in. Once I'm happy with this set up I will be going nuts with the boost and other mods, hopefully making around 300-350+RWKW. Which fuel pump and injectors would you guys reccomend to use to accomodate this sort of power?? Its a BF MKII Ute so should I invest in some sort of surge tank or something as well to stop any lean outs that may occur? Any help is appreciated guys! Cheers. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 11m 23d Gender: Male Location: SW Sydney Posted 24/09/08 01:35 AM Share Posted 24/09/08 01:35 AM Either the Bosch 968's or the Siemens Dekas will do the job, but the dekas are going to have more scope if you want to push closer to 400 - and with a forged bottom end why wouldn't you?You could look at the Process West surge tank, or alternatively search for hanra's thread about how he did one himself on his ute. Link to comment Share on other sites More sharing options...
Guest Guests Posted 24/09/08 01:49 AM Share Posted 24/09/08 01:49 AM Easiest way & best IMO is the Deka's & PW Surge setup. For around $1200 you'll have plenty for 400rwkw if you end up there Link to comment Share on other sites More sharing options...
Azzman460 Azzman Member 223 Member For: 16y 6m 8d Gender: Male Location: Melbourne Posted 24/09/08 05:07 AM Author Share Posted 24/09/08 05:07 AM so will the dekas be ok to run the standard typhoon/turbo tuning whilst I run the car in? Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 11m 23d Gender: Male Location: SW Sydney Posted 24/09/08 05:10 AM Share Posted 24/09/08 05:10 AM No they are too big to run on the standard tune, if you have the stock injectors, just use them until you are ready to get a tune. Alternatively you could get a "run in" tune that is scaled to the dekas Link to comment Share on other sites More sharing options...
Azzman460 Azzman Member 223 Member For: 16y 6m 8d Gender: Male Location: Melbourne Posted 24/09/08 05:13 AM Author Share Posted 24/09/08 05:13 AM ok then I have typhoon injectors so I'll run them to begin with then swap to the dekas for a more agressive tune. Will a surge tank be neccessary with the ute? I've read that the utes arent to bad with the surging problems. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 11m 23d Gender: Male Location: SW Sydney Posted 24/09/08 05:23 AM Share Posted 24/09/08 05:23 AM They aren't quite as neccesary in the utes, but they are a good safety barrier just incase you get a bit carried away with a quarter of a tank. Link to comment Share on other sites More sharing options...
Azzman460 Azzman Member 223 Member For: 16y 6m 8d Gender: Male Location: Melbourne Posted 24/09/08 07:19 AM Author Share Posted 24/09/08 07:19 AM cool. So where would you guys recommend to get the dekas and surge setup from? do any forum advertisers give good deals on these parts? or will I have to look around? Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 11m 23d Gender: Male Location: SW Sydney Posted 24/09/08 07:22 AM Share Posted 24/09/08 07:22 AM Shop around a bit mate, the dekas can be had on Ebay, a site advertiser RAP1D sells them and so does just about all the workshops. The surge tanks can be had From Process west or again most workshops can sort something out. Link to comment Share on other sites More sharing options...
simmo Member 431 Member For: 21y 11m 21d Gender: Male Location: byron bay more underarm hair per square km Posted 24/09/08 10:35 AM Share Posted 24/09/08 10:35 AM (edited) im looking at injectors at the moment and have been told that the dekas can cause rough idle is this correct ?I hope not cause the dekas are a damn site cheaper than the 968s Edited 24/09/08 10:35 AM by simmo Link to comment Share on other sites More sharing options...
