  • New Member
  • Member For: 16y 9m 9d
I've done a few searches and cant find the info I was looking for. Is there a thread on the difference between the BA and the BF? That is, was there any difference in the motor, brakes, ect.
Also what difference is there between the BF and BFII?
If there is a thread on this could someone link it for me or tell me what to type in the search box. It would be much appreciated.
https://www.fordxr6turbo.com/forum/topic/49553-ba-bf-specs/
Not sure if there is a dedicated thread but there is talk of it in a few threads. Can't help with a search term but I'll try give you a run down.
Main differences are the engine, box & brakes.
BA mk I
5 speed manual or 4 speed auto
piss weak conrods
Brakes that couldn't stop a pushbike unless they have the PBR upgrade
Cruel driveline shunt
BA mk II
6 speed manual or 4 speed auto
Same weak rods
Same ridiculous brakes
Same old driveline shunt!
BF mk I
6 speed manual or 6 speed auto
Same rods
Larger diameter rotors & bigger calipers
Driveline shunt
BF mk II
Same rods as Typhoon, can handle more power
Same brakes as BF mk I
You guessed it, free driveline shunt :tonguepoke:
Edited by 03XR6T
https://www.fordxr6turbo.com/forum/topic/49553-ba-bf-specs/#findComment-731110
  • New Member
Thanks for the reply 03XR6T had a laugh at the brake comments. What year did BF MKII come out? I heard something about different valve springs in the motor as well, is that correct?
https://www.fordxr6turbo.com/forum/topic/49553-ba-bf-specs/#findComment-731119
  • Member For: 17y 9m 27d
I'm pretty sure BFII's are late 06 dated mate; if I'm wrong someone will definately correct me!! As for valve springs, in your later model falcons I dont think they're as much of an issue as in the BAMK1's and II's. Although, going through some threads people with BAMK2 standard valve springs are pulling good power and some aren't. Long short of it all, its a worth while mod because you cant tell if you need them or not until you start tuning and they've come down alot in price lately as well! Hope this helps:)
https://www.fordxr6turbo.com/forum/topic/49553-ba-bf-specs/#findComment-731144
  • Member For: 18y 3m 21d
There was also a massive increase in power from BA MKII to BF... a WHOPPING 5kW... not sure on torque figures though without looking them up. Then you got all the little interior/exterior differences like the led taillights, satin chrome door insert pieces, dash cluster change, etc...
I think it went...
BA MKI - OCT 2002 To OCT 2004
BA MKII - OCT 2004 TO SEPT 2005
BF MKI - SEPT 2005 TO OCT 2006
BF MKII - OCT 2006 - JUNE 2008 OR somewhere thereabouts....
Were the PBR brakes on BA series bigger or smaller than the standard BF brakes?
Edited by Joshy
https://www.fordxr6turbo.com/forum/topic/49553-ba-bf-specs/#findComment-731339
  • Member For: 17y 4m 10d
Inside my ba series 1 also had extra vents on the side below the big one near the window. The bf series 2 does not have this, but maybe because the ba was a premo pack, vs our bf povo pack. I know that this is a huge difference.
https://www.fordxr6turbo.com/forum/topic/49553-ba-bf-specs/#findComment-731392
