SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 6m 1d Gender: Male Posted 26/10/11 08:48 AM Share Posted 26/10/11 08:48 AM I must have done 5-7000kms with my setup now and there is still barely any oil in the little filter between the rocker breather and the crossover. I have checked the catch can between the PCV and the intake manifold and there is a bit in there though. Link to comment https://www.fordxr6turbo.com/forum/topic/49463-oil-catch-can/page/8/#findComment-1153812 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 18y 22d Gender: Male Location: Melbourne Posted 26/10/11 08:54 AM Share Posted 26/10/11 08:54 AM Have you got a picture of your setup mate, I don't think you would need a filter would you? Link to comment https://www.fordxr6turbo.com/forum/topic/49463-oil-catch-can/page/8/#findComment-1153815 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 14d Gender: Male Location: Townsville Posted 26/10/11 01:15 PM Share Posted 26/10/11 01:15 PM The back line with the PCV on it is where all the oil from and ends up in the runners of the B series Turbo's. I have a cheap paper fuel filter on the front breather and there is lucky to be a quarter of a teaspoon after maybe 5k km's.If I ever get time and remember I will drop the oil from the rear breather catch can to see whats in there but going off what the runners looked like before I put it on then there should be a decent amount inside.I run anywhere from 16-20psi also. Link to comment https://www.fordxr6turbo.com/forum/topic/49463-oil-catch-can/page/8/#findComment-1153889 Share on other sites More sharing options...
Tobey Awesome... Member 407 Member For: 14y 11m 12d Gender: Male Posted 27/10/11 12:36 AM Share Posted 27/10/11 12:36 AM I run two $3 inline fuel filters on both of my breathers, does the job, pretty discreet.... Link to comment https://www.fordxr6turbo.com/forum/topic/49463-oil-catch-can/page/8/#findComment-1153942 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 6m 1d Gender: Male Posted 27/10/11 07:49 AM Share Posted 27/10/11 07:49 AM I'll get a pic up shortly Link to comment https://www.fordxr6turbo.com/forum/topic/49463-oil-catch-can/page/8/#findComment-1154051 Share on other sites More sharing options...
FORDCRAZY Member 36 Member For: 14y 1m 28d Posted 18/02/12 04:59 PM Share Posted 18/02/12 04:59 PM Great write up. Now from what Ive read here the rear pcv is the culprit for oil in the intake system. I've been running a catch can for the front rocker cover line (and I can say that with 5-10k km ther is. Bugger all oil in the can). So would it be best to change my setup by; plugging the hole on crossover, and putting filter breather on rocker cover. Then use my catch can for the rear pcv/intake manifold??P.s I fitted my can on the factory air box. Quick and easy. Very concealed. I've used black hoses and if I paint the can black, most ppl won't even spot it. Can post pic if anyone interested. Link to comment https://www.fordxr6turbo.com/forum/topic/49463-oil-catch-can/page/8/#findComment-1198363 Share on other sites More sharing options...
MX Dave Donating Members 545 Member For: 14y 2m 12d Gender: Male Posted 19/02/12 03:51 AM Share Posted 19/02/12 03:51 AM On 18/02/2012 at 4:59 PM, FORDCRAZY said: Great write up. Now from what Ive read here the rear pcv is the culprit for oil in the intake system. I've been running a catch can for the front rocker cover line (and I can say that with 5-10k km ther is. Bugger all oil in the can). So would it be best to change my setup by; plugging the hole on crossover, and putting filter breather on rocker cover. Then use my catch can for the rear pcv/intake manifold??P.s I fitted my can on the factory air box. Quick and easy. Very concealed. I've used black hoses and if I paint the can black, most ppl won't even spot it. Can post pic if anyone interested.To be legal it has to go back into the inlet tract.So fill your catch can with stainless steel scourers and it will get 90% if not all of the oil particles before it goes back into the inlet.On another note my catch can off the pcv after 7000kms has probably got about half a cup of oil in there. not including all the residue left on the scourers. Link to comment https://www.fordxr6turbo.com/forum/topic/49463-oil-catch-can/page/8/#findComment-1198489 Share on other sites More sharing options...
JGP Donating Members 309 Member For: 14y 9m 20d Gender: Male Posted 19/02/12 11:22 PM Share Posted 19/02/12 11:22 PM does having so much oil signal turbo is getting on or any other issues? others say after 100k they have barely anything in the catch can Link to comment https://www.fordxr6turbo.com/forum/topic/49463-oil-catch-can/page/8/#findComment-1198782 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 14d Gender: Male Location: Townsville Posted 20/02/12 11:38 AM Share Posted 20/02/12 11:38 AM Depends on boost levels, what oil brand and thickness you use. So many variables though but unless its chewing through oil I wouldn't worry! Link to comment https://www.fordxr6turbo.com/forum/topic/49463-oil-catch-can/page/8/#findComment-1199193 Share on other sites More sharing options...
RICFORD Member 84 Member For: 14y 5m Gender: Male Location: sydney Posted 20/02/12 11:42 PM Share Posted 20/02/12 11:42 PM (edited) Can any catch can do the job? I've seen heaps on ebay going for $30 - $150.Is there a particular brand or style that's more suited for our cars? Edited 20/02/12 11:43 PM by RICFORD Link to comment https://www.fordxr6turbo.com/forum/topic/49463-oil-catch-can/page/8/#findComment-1199378 Share on other sites More sharing options...
