Oil Catch Can
  • in the mid....not the bum like some
  • Member For: 11y 9m 24d
I ended up running two AN12 weld-on fittings on the rocker cover and deleted the PCV circuit all together.
AN16 weld-on with AN16-AN12 reducer on the turbo intake to the MOROSO AN12 sealed oil/air separator.
In a performance application you would want AN8 at the very minimum on these cars.
  • Sandtrap Motorsport
  • Member For: 16y 2m 22d
Why the -16 to -12 reducer? Paying extra for no reason.
I have -16 weld ons, and lines.
But I suspect -16 elbows cost less than -16>-12 reducers ?
  • Member For: 11y 4m 17d
I've got 2 -10 on mine but on a SOHC motor doesn't get stuff all in the can but with twin -6 size holes previously and would allways leak out the rocker cover gasket, but then that could also be because the motor has done 350000km and has 20psi of boost rammed in it haha
Sent from my iPhone using Tapatalk
  • Member For: 17y 2m 23d
My kind of bloke. Out done me both on kms and boost!
Visual effect and it needed a series of fittings adding up to about 5" in length before I wanted the hose to start.
A 16-12 reducer is only $15.
Glad Im not the only one who fits a decent size breather port to the heads RB or not.
  • Moar Powar Babeh
  • Member For: 19y 4m 24d
Ask Tocchi to explain the setup he's running and the size of the breather lines will make sense.
Re the -8 as a minimum comment. My. Motor is built. Mahle pistons and atomic rods. The pistons are noisy on intial start up but calm down once it's warm. I'm pushing 20lb into it everyday on either e85 or P98 and guess what... Zero issue with my pcv or crankcase breather setups.
So meh.
