Pearse Member 21 Member For: 13y 10m 7d Gender: Male Location: Perth Posted 01/04/11 10:39 AM Share Posted 01/04/11 10:39 AM Ok so I did a couple of tests, stole some power from the igition barrel light and hooked it straight up to the 12v constant at first, turned the key and I got a relay noise from the engine bay then a low pitch beep and the abs light and a hazard light came on the dash, also my stereo now says code when you try turn it on, this is getting bad Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 21y 10m 27d Gender: Male Location: Sydney Posted 01/04/11 10:49 AM Share Posted 01/04/11 10:49 AM We tried to tell you that wiring in a turbo timer was a waste of time, now its introduced a whole load more of problems......Im sure the convenience of a turbo timer isnt as good as having a car that starts! Put the timer on ebay, return your wiring back the way it was, and get on with life. Link to comment Share on other sites More sharing options...
Pearse Member 21 Member For: 13y 10m 7d Gender: Male Location: Perth Posted 01/04/11 11:20 AM Share Posted 01/04/11 11:20 AM The first thing I did was return the wiring back to how it was, there is no turbo timer anymore, I still can't start my car, I've checked all fuses twice now, I think it's either alarm related or ecu related, how can I test this? I've removed the negative battery terminal which I read on here "resets" the ecu, not sure how true that is, I've also read of a very similar problem from another member which was just his ignition fuse, I can assure you mine is fine, I really wish I hadn't of attempted it now Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 21y 10m 27d Gender: Male Location: Sydney Posted 01/04/11 12:16 PM Share Posted 01/04/11 12:16 PM Check all the big boxy fuses out, you will probably have to run a multi meter across them to properly test them. Link to comment Share on other sites More sharing options...
Pearse Member 21 Member For: 13y 10m 7d Gender: Male Location: Perth Posted 01/04/11 12:20 PM Share Posted 01/04/11 12:20 PM Ok will have to borrow a multimeter tomorrow. Are we still stuck on fuses? is it completely out of the question that by shorting out the constant 12v, acc and coil wires, I've triggered an alarm or complete shut out? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 1d Gender: Male Location: Perth Posted 01/04/11 12:23 PM Share Posted 01/04/11 12:23 PM I haven't figured that out yet, but today I accidentally touched one or all of the 3 wires together whilst my car was running and it died, now I can't get it to start again, any help would be appreciatedAt least now you'll have no problem with the turbo bearings. Link to comment Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 1m 20d Gender: Male Location: Perth, NOR Posted 01/04/11 12:41 PM Share Posted 01/04/11 12:41 PM checked fuses? Link to comment Share on other sites More sharing options...
Pearse Member 21 Member For: 13y 10m 7d Gender: Male Location: Perth Posted 01/04/11 12:50 PM Share Posted 01/04/11 12:50 PM A few times now yeah, I'm wondering if the fact that my stereo says code has anything to do with it?? Link to comment Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 1m 14d Gender: Male Location: Dé·jà vu Posted 01/04/11 04:01 PM Share Posted 01/04/11 04:01 PM Put the timer on ebayTrade It In... Ignore this post Pearse. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 1d Gender: Male Location: Perth Posted 01/04/11 04:09 PM Share Posted 01/04/11 04:09 PM I live in Perth. If you cant get it going call me. Iam an electrician and a mechanic. Arron 0411733583 Link to comment Share on other sites More sharing options...
