Turbo Noiser After Cooler Fitted
GCTXR6
  • Member For: 16y 7m
fitted a rapid systems v1 cooler the other week and have noticed the turbo whistle much louder on drivers side
all clamps are tight and no leaks as far as I can see .
I removed the front pipe and inspected the turbo and it had minor movement up and down and also front to back ?
no evedence of touching the front cover or blades damaged
the car has a custom tune to about 12psi but I havent got up up full throttle since the a retune is need
also as I have a magnaflow 3inch cat to be fitted then the lpg is being tuned for the new set up
but it comes on boost no probs and not noisey on idle or when car turned off (no more than it always had )
cars done 92km
  • 2 weeks later...
  • Well-Hard Bangin' Member
  • Member For: 17y 2m 24d
Yep, sounds like it's just flowing more air mate, wouldn't worry about it just enjoy it. get your tuner to check it out if you are worried.
and I really don't think Chris @ RAPIDSystems is the kind of person to leave little bits of alloy in without cleaning it out :rolleyes:
hi have you fixed it? what was it? a mate thinks his is doing the same
its at the panel beaters getting a front bumper and bonnet painted then ill get simon at xft to drive if ill let you know :stupid:
