MercuryXr6Turbo Member 361 Member For: 16y 5m 4d Gender: Male Location: Perth, WA Posted 14/10/08 12:38 PM Share Posted 14/10/08 12:38 PM Hey to all that posted on this question, I was also wondering who to go to here in Perth! Choice seems pretty clear... :-)I've only just bought my BA XR6T Auto (stock standard) but sounds like a flash tuner, custom Xtreme tune, 60lb injectors and fuel pump are a good start???Can anyone comment if they have similar to this work done and how it effects fuel economy? Assume will use more but it it alot more?Also is this safe considering all internals are standard / gearbox standard etc?Cheers guys... Link to comment Share on other sites More sharing options...
Guest Guests Posted 14/10/08 12:48 PM Share Posted 14/10/08 12:48 PM Throw a high flow cat in the mix & you could expect 290 - 300rwkw with a BA XR6T. You probably wouldn't want to go much more on the 4 speed as they start to play up...Fuel economy will be much worse due to the right foot being planted permanently Link to comment Share on other sites More sharing options...
MercuryXr6Turbo Member 361 Member For: 16y 5m 4d Gender: Male Location: Perth, WA Posted 21/10/08 02:18 PM Share Posted 21/10/08 02:18 PM Thanks heaps 03XR6T, and yeah your probably right about the fuel economy!!! :-) ... I got a chance to drop into Xtreme and have a chat, they also said the CAT would be a good addition to the combo money permitting. The only thing that's thrown a spanner in the works is that they said having a BA even just a tune alone I'm likely to have problems with the Valve Springs. With you having a BA also how are yours holding up... or did you get them changed? Its just they arent the cheapest things to get done. Appreciate all the help! Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 8m 11d Gender: Male Posted 22/10/08 12:52 AM Share Posted 22/10/08 12:52 AM 03 traded his ba, but he did get 300 at the treads on the stock ones with a high flow cat. Link to comment Share on other sites More sharing options...
