MrBean Member 400 Member For: 18y 11m 6d Location: Melbourne Posted 12/09/08 11:41 AM Author Share Posted 12/09/08 11:41 AM Heya Steve,Yep, it's like one of them good novels - and I luv reading.The only pics I have of my progress is the Dev Board, and J-TAG programmer for the AVR - lols. Lot's of studies ahead of me for the next 2-3 weeks, have to get all the required signals sorted, then determine which bits/bytes they represent in the CAN-message structure, and document all that.Once we have all this data, can we begin programming. We might even get some of our more gifted coders here to do something in C, as there exists decent C-Compilers for this AVR - will be easier to do than assembler.So:1) we need to capture all s/ware variables, external IO-signals2) Need to assign physical inputs to suitable ports on the AVR, for example Incr Temp will go to port 1, bit6, Decr Temp port 1, bit7...and so on - just a simplified description.3) Once the hardware layout is complete, and we know what IO's are on which ports, can we start coding.So, will be a bit before we get there, but I will dedicate a fair bit of my limitied free time over the next couple of weeks to get to the stage immediate prior to coding - then I will need some help.If someone else wants to study the CAN-messaging and start working on that, it will be handy. Link to comment https://www.fordxr6turbo.com/forum/topic/49192-project-opensource-icc-hardware-software/page/6/#findComment-732841 Share on other sites More sharing options...
glimmerman Member 90 Member For: 16y 7m 29d Gender: Male Location: Penrith, NSW, OZtralia Posted 12/09/08 12:02 PM Share Posted 12/09/08 12:02 PM So with the previous carputer project, did you end up disassembling everything, such as the glove box mounted mac? Or are you planning to still use the stainless steel ball to hook up to this ICC replacement and then just remove the mac? Or has all of it sorta sat as is while you conquer this project? lol Link to comment https://www.fordxr6turbo.com/forum/topic/49192-project-opensource-icc-hardware-software/page/6/#findComment-732865 Share on other sites More sharing options...
MrBean Member 400 Member For: 18y 11m 6d Location: Melbourne Posted 12/09/08 12:04 PM Author Share Posted 12/09/08 12:04 PM (edited) Glimmerman said: So with the previous carputer project, did you end up disassembling everything, such as the glove box mounted mac? Or are you planning to still use the stainless steel ball to hook up to this ICC replacement and then just remove the mac? Or has all of it sorta sat as is while you conquer this project? lolHa, soz, I thought you were referring to just the emulator-portion of the project...the carputer is ready to roll, it's up and running, I have the 8.4" Transflective, the stainless trackball is mounted in the UTE, I am busy with an "enclosure" for it to replace the standard cupholder - I ordered and received a huge 2.44x1.44 m/2 ABS sheet from CityPlastics earlier in the week - I need a small bit of this for some ABS work on the fascia et al.Will post pics of this in the carputer log as I progress. The carputer will sit behind the "old" ICC fascia - will be plenty of real-estate, as the new ICC-emulator will be smaller than a pac of 20's sigarettes.Below some inter-node communications data, pertaining to HIM/ICC/BEM/PCM. We still need the comm's from/to Instrument Cluster (IC) - but, we will get there. The part that is of particular interest to us is the to/from ICC variables:Information Description Sender Receiver ACC MCC HTR--------------------------------------------------------------------------------------------------------Air Inlet Mode (Refresh/Recirc) HIM ICC Y Y YAir Outlet Mode (Face /Floor/Screen) HIM ICC Y Y YPerson Display Icon HIM ICC Y Y YA/C Display Icon HIM ICC N Y NA/C Max Display Icon HIM ICC N Y NA/C Off Display Icon HIM ICC Y N NBlower Fan Speed Manual Selection HIM ICC Y N NDrivers Side Temperature Selection HIM ICC Y N NPassenger Side Temperature Selection HIM ICC Y N NAmbient Temperature HIM ICC Y N NClimate Control mode (Auto/Semi/Off) HIM ICC Y N N--------------------------------------------------------------------------------------------------------Blower fan motor operating speed V HIM PCM Y Y YEvaporatore Core Surface Temperature HIM PCM Y Y NA/C Compressor engagement request HIM PCM Y Y N-------------------------------------------------------------------------------------------------------Blower / Temp Knob Positions ICC HIM N Y YClimate Control Push Buttons ICC HIM Y Y YICC Module Type (Auto/Manual/Climate) ICC HIM Y Y Y-------------------------------------------------------------------------------------------------------Ignition Switch Accessory Position BEM HIM Y Y YCabin Temperature Sensor BEM HIM Y N NSun Load Sensor BEM HIM Y N N-------------------------------------------------------------------------------------------------------- Engine RPM PCM HIM Y Y YVehicle Road Speed PCM HIM Y Y YDTC Logging Enable PCM HIM Y Y YA/C Load Reduction PCM HIM Y Y NEngine Coolant Temperature PCM HIM Y N NEngine Cylinder Count PCM HIM Y N N--------------------------------------------------------------------------------------------------------edit: Posting this somehow screws with the rows/columns format, so find attached text file for better clarity.Node_CAN_Communications.txt Edited 12/09/08 12:12 PM by MrBean Link to comment https://www.fordxr6turbo.com/forum/topic/49192-project-opensource-icc-hardware-software/page/6/#findComment-732870 Share on other sites More sharing options...
glimmerman Member 90 Member For: 16y 7m 29d Gender: Male Location: Penrith, NSW, OZtralia Posted 13/09/08 12:20 AM Share Posted 13/09/08 12:20 AM CoolSo in short response (lol) the mac is gone, but pretty much everything else remains, and the carputer is now moved to behind the facia, and you are keeping the rest as is (apart from the facia itself)Sounds cooo oooolSteve Link to comment https://www.fordxr6turbo.com/forum/topic/49192-project-opensource-icc-hardware-software/page/6/#findComment-733161 Share on other sites More sharing options...
MrBean Member 400 Member For: 18y 11m 6d Location: Melbourne Posted 13/09/08 01:53 AM Author Share Posted 13/09/08 01:53 AM I still have the Mac Mini, as well as a Commell LV-677 in a very neat Industrial Serener GS-L05, and then a smaller Commell LS-372 in a temporary custom case for now - see pics below for how small this LS-372 really is - I fitted it in a dual 3.5" harddrive enclosure, with room to spare. andandThese LS-372's are very powerful, the ideal candidate for the Carputer environment - it has similar specs to the LV-677, but in a small factor the same size as your 3.5" computer harddrive - neat, hey?Hehe...I have to many toys. Link to comment https://www.fordxr6turbo.com/forum/topic/49192-project-opensource-icc-hardware-software/page/6/#findComment-733221 Share on other sites More sharing options...
SubJimbo ŠύЂפֿĺmβø ™ Donating Members 1,216 Member For: 17y 3m 10d Gender: Male Location: Melbourne Posted 13/09/08 01:58 AM Share Posted 13/09/08 01:58 AM Very nice beanie, Ive been playing around with a Commell LV 674E, They are very nice boards!, The 7.1ch Audio is also very cool Ive got it all set up on my dining table, with my 10.4" touchscreen etc.. I'm just waiting for this project to progress to see what I want to do with it! Should I install the 10.4" Touchscreen? Decisions, Decisions.. Link to comment https://www.fordxr6turbo.com/forum/topic/49192-project-opensource-icc-hardware-software/page/6/#findComment-733225 Share on other sites More sharing options...
glimmerman Member 90 Member For: 16y 7m 29d Gender: Male Location: Penrith, NSW, OZtralia Posted 13/09/08 01:11 PM Share Posted 13/09/08 01:11 PM Guys,Sounds fantastic, - Bean, really like the look of the board and the system size, fantastic.I'd go and get my hands on the boards you have so far, but don't wanna risk it incase something changes - I make a :hiwelcome: wage lol, is there anything at the moment that you think will not be changed and stay within the project? - Or once its working, are you going to assemble some for those who would like them and send them out?Steve Link to comment https://www.fordxr6turbo.com/forum/topic/49192-project-opensource-icc-hardware-software/page/6/#findComment-733526 Share on other sites More sharing options...
MrBean Member 400 Member For: 18y 11m 6d Location: Melbourne Posted 17/09/08 09:03 AM Author Share Posted 17/09/08 09:03 AM SubJimbo said: Should I install the 10.4" Touchscreen? Decisions, Decisions..Go on, you know you want to :-) Glimmerman said: I'd go and get my hands on the boards you have so far, but don't wanna risk it incase something changesNope, you can go ahead, this unit will really be pretty much independant, once we get the basics going, we can then finetune, and at a later stage integrate an USB interface between the Carputer and Microcontroller, and use a front-end plugin to control the HVAC once the carputer is running.I have currently identified the overlay control chip in the LCD controller Ford uses, and we may even go so far as to develope an overlay control onto our aftermarket screens - but, I'm jumping the gun a little, but these are real possibilities.So yes, a fair ways to go still.I will post the bit-related data for all the control-signals either tomorrow or Friday evening, with Lukey's help we have a complete list of exactly where in the CAN message structure these are located.Will keep you all posted. Link to comment https://www.fordxr6turbo.com/forum/topic/49192-project-opensource-icc-hardware-software/page/6/#findComment-736019 Share on other sites More sharing options...
glimmerman Member 90 Member For: 16y 7m 29d Gender: Male Location: Penrith, NSW, OZtralia Posted 20/09/08 02:16 AM Share Posted 20/09/08 02:16 AM So how did it go? lol Link to comment https://www.fordxr6turbo.com/forum/topic/49192-project-opensource-icc-hardware-software/page/6/#findComment-737576 Share on other sites More sharing options...
MrBean Member 400 Member For: 18y 11m 6d Location: Melbourne Posted 20/09/08 11:54 PM Author Share Posted 20/09/08 11:54 PM @ Glimmerman: I'm still awaiting the ICC unit Tree Monkey donated to this cause :-)I will post up the bit-data for the messaging tonight, but before receiving the ICC I cannot make real hardware progress.Br,Beanie Link to comment https://www.fordxr6turbo.com/forum/topic/49192-project-opensource-icc-hardware-software/page/6/#findComment-737916 Share on other sites More sharing options...
