  • Member For: 18y 1m 22d
I believe you would be looking at.
1.bigger intercooler
2.more boost
3. maybe a more aggressive tune but I doubt it
That is probably it but im sure someone can tell you for sure
https://www.fordxr6turbo.com/forum/topic/49008-270kw-315-kw/#findComment-722806
  • Member For: 18y 7m 17d
Going by what some tuners have done already, all you'll need in a FG XR6t is a custom tune and you'll be doing much more than 310kw at the engine.
That said, I believe the Typhoon runs a bigger turbo (the one used in the BA-BF series), and a bigger intercooler, among other things, including a more aggressive tune.
Edited by Dagabond
https://www.fordxr6turbo.com/forum/topic/49008-270kw-315-kw/#findComment-722886
  • It's not a MKI!
  • Member For: 16y 10m 16d
No F6 Typhoon came out with 315kw standard.
The FG F6, however, came out standard with 310kw.
The FGXR6T came out with a smaller impellor on the turbo and the F6 uses the same turbo as the BA/BF.
Injectors and intercooler are of a larger capacity on the F6 also.
I'm not sure about the exhaust system either. It may be larger on the F6.
https://www.fordxr6turbo.com/forum/topic/49008-270kw-315-kw/#findComment-722898
