Motorolla Bluetooth In Ba Mkii How To(should Be The Same Across The Ra
quadie
  • Member For: 19y 3m 16d
ok here goes :
located behind the fuse panel (near where u pop ya bonnet), pop the fuse panel cover off
now behind there u will see a few empty plugs locate a 4pin square plug.
the wiring for this plug should be : orange,black,black with yellow trace,green
This is your power feed and ICC trigger point
the second plug u need to find is the Audio input for the ICC, this is a T shaped plug with pink and grey wires
ok so hoping u have the same wire colours as my motorolla kit ( I fitted my kit about 3 yrs ago and dont have a wiring diagram for it)
it sould match this :
4 pin Square plug
CAR | MOTOROLLA
Orange | Red
Black | Black
BLK/Yellow| Green
Green | Orange
2 pin - get the speaker box from the car kit and chop the speaker off. (its not too fussy on polarity this plug)
SPK+ | Pink
SPK - | Grey
Use male spade terminals for both plugs !
I mounted the module in the space on the drivers sider of the ICC behind the panel(other side of the steering wheel to the wiring)
pair up your phone and test :)
the ICC will go into AUX/PHONE on the display and cuts audio from cd/radio and feeds the bluetooth kit audio ..
I had to mess with the volume of the bluetooth and the icc to get the best sound , but its good :)
any probs , drop me a pm
Edited by quadie
I havent been using an AUX input when I reived a call so I cant answer that mate
and yes mine says media too
  • 2 weeks later...
