4DZILR Donating Members 713 Member For: 15y Gender: Male Location: Sydney - Brighton Le Sands Posted 28/09/10 03:34 AM Share Posted 28/09/10 03:34 AM Will it make a difference on stock car? no tune.. to change to .8? Link to comment Share on other sites More sharing options...
4DZILR Donating Members 713 Member For: 15y Gender: Male Location: Sydney - Brighton Le Sands Posted 28/09/10 04:29 AM Share Posted 28/09/10 04:29 AM (edited) Just payed $84 for NGK Iridium .8m plugs.. Edited 28/09/10 04:30 AM by 4DZILR Link to comment Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 2m 27d Gender: Male Location: left right out Posted 28/09/10 05:35 AM Share Posted 28/09/10 05:35 AM I went for .8 plugs on a stock tune knowing I was doing work and a tune in 6 months or so. Runs fine on stock factory tune. Link to comment Share on other sites More sharing options...
Robos F6 Donating Members 407 Member For: 15y 11m 3d Gender: Male Location: Vic Posted 28/09/10 06:22 AM Share Posted 28/09/10 06:22 AM BKR6EIX are the iridiums you want allready gapped to 0.8mmBKR6EIX-11 use the larger gap of 1.1mm Link to comment Share on other sites More sharing options...
Psychotiq Member 37 Member For: 14y 14d Gender: Male Location: QLD Posted 10/09/11 06:42 AM Share Posted 10/09/11 06:42 AM well gave this a crack today, Number 1 and 2 gave me no problems, but the rest of the coils would NOT come out, after trying for 5min with coil 3 the top of the coil came off with the spring from inside still attached, and the body was still down the shaft attached to the spark plug, scared me, so threw it back in, and only got to change 2 of the 6. Not sure why the top broke off, but I think I'll leave it for my next upcoming service. I don't want something to happen. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 5m 1d Gender: Male Location: Townsville Posted 10/09/11 10:28 AM Share Posted 10/09/11 10:28 AM I just grabbed the spring with a pair of needle nose pliers and removed it. Try not to pull to fast as the spring may stretch which isnt a biggy but keeping iot the same would be better. Try WD40 or INOX soften the rubbers from the alloy head. Link to comment Share on other sites More sharing options...
aussie1926 Donating Members 176 Member For: 14y 11m 14d Gender: Male Location: Muswellbrook NSW Posted 23/10/11 06:00 AM Share Posted 23/10/11 06:00 AM If you put grease on use a dielectric grease Link to comment Share on other sites More sharing options...
Slymeat Team Kickass Donating Members 1,926 Member For: 21y 8d Gender: Male Location: Albion Park, NSW Posted 04/11/11 12:17 AM Share Posted 04/11/11 12:17 AM No.6 bites it took me more time to do no.6 than the other 5. Link to comment Share on other sites More sharing options...
Whosh Member 5 Member For: 12y 9m 28d Gender: Male Posted 16/06/12 05:58 AM Share Posted 16/06/12 05:58 AM Well Mike, your spark plug replacement write up is awsome my friend. Changed my plugs today, coils as well, job was a breeze after reading your post. Thank you for your effort in doing so . Regards Mick Davis. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 11d Gender: Male Location: Probably above atmospheric pressure Posted 19/08/12 02:35 PM Share Posted 19/08/12 02:35 PM (edited) Had a breeze of a time changing coils and plugs for the first time ever today thanks to the guide, good on ya. Hardest part was getting the crossover off and I've done that I don't know how many times now while doing general service.#6 plug wasn't even that hard, though I couldn't fit my universal joint in there as it is too wide, had to go with assembling the extensions while in the hole as described. Think I'll buy a low range torque wrench though so I know they are done up to spec, 1/4 turn after it started to tighten felt pretty tight on a couple so I didn't push it all the way.Fingers crossed these VDO coils dont' sh!t themselves too quickly.Went with genuine Motorcraft SK20R7 (0.7mm) plugs as seen on left here. Used plugs are probably at least 140,000km - never changed since I bought her so possibly 170,000km. Edited 19/08/12 02:36 PM by -SteveR- Link to comment Share on other sites More sharing options...
