PHANTMXR6 It's not a MKI! Member 1,742 Member For: 17y 15d Gender: Male Location: Earth Posted 03/01/09 02:45 PM Share Posted 03/01/09 02:45 PM If you dropped them in the hole then I would definately be removing them and checking them.Make sure you place them in there nicely next time. Link to comment https://www.fordxr6turbo.com/forum/topic/48973-mikes-step-by-step-guide-to-replacing-spark-plugs/page/4/#findComment-795474 Share on other sites More sharing options...
Mike XR6T iTs alL DaRDy........ Donating Members 780 Member For: 17y 9m 29d Gender: Male Location: Adelaide Posted 03/01/09 09:21 PM Author Share Posted 03/01/09 09:21 PM definatly take them out and check the gap matesounds like that's your problem Link to comment https://www.fordxr6turbo.com/forum/topic/48973-mikes-step-by-step-guide-to-replacing-spark-plugs/page/4/#findComment-795496 Share on other sites More sharing options...
wolfee Member 25 Member For: 16y 7m 23d Posted 17/01/09 12:16 AM Share Posted 17/01/09 12:16 AM (edited) ive been trying to get some BKR6EIX pre gapped at 0.8 but can only find mainly BKR6EIX-11 which is gapped at 1.1 anyone got a link for the 0.8 plugs maybe ebay? thanks. Edited 17/01/09 12:17 AM by wolfee Link to comment https://www.fordxr6turbo.com/forum/topic/48973-mikes-step-by-step-guide-to-replacing-spark-plugs/page/4/#findComment-804537 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 17y 15d Gender: Male Location: Earth Posted 17/01/09 02:32 AM Share Posted 17/01/09 02:32 AM The part number for the 0.8mm gapped plugs, apparently, is exactly as you have posted.BKR6EIX Link to comment https://www.fordxr6turbo.com/forum/topic/48973-mikes-step-by-step-guide-to-replacing-spark-plugs/page/4/#findComment-804581 Share on other sites More sharing options...
messna Donating Members 57 Member For: 16y 6m 28d Gender: Male Location: adelaide Posted 31/01/09 06:12 AM Share Posted 31/01/09 06:12 AM I have just bought some .8 gap spark plugs from repco for $ 22 each and installed my 10 psi tune, runs sweet as. cheers Link to comment https://www.fordxr6turbo.com/forum/topic/48973-mikes-step-by-step-guide-to-replacing-spark-plugs/page/4/#findComment-813905 Share on other sites More sharing options...
graham_h Member 39 Member For: 16y 8m 6d Posted 31/01/09 07:54 AM Share Posted 31/01/09 07:54 AM hey alljust an update:after replacing my standard plugs(1.1mm gap)with NGK BKR6EIX (0.8mm gap)I have notice a big mid to top end proformance gain.Anyone that has had a tune should change to these plugs.The car is so much better up top and also mid range there is much more. the reason being:Using the standard gaps under boost the coils need to produce more energy to jump the plug gap, most of the energy is used to jump the large gap and there fore not much energy is left for a long duration(burn time). A smaller gap means more energy is saved for a longer burn time therefore betetr combustion in each cylionder! and more power!To explain: a coil can only produce so muc h energy. that energy is divided into 2 sections 1: the Firing voltage- the energy required to make the initial jump of the plug gap.2: the left over energy is used to continue the burn time(duration) for as long as possibel til there is no energy left thus giving complete combustiopn.I would recommend anyone that has had a tune and still running standard plugs to follow the guide and spend an hour or so changing the plugs for a big improvement in driveability up top.cheersps under larger boost amounts more energy is used to make the initial arc across the gap and that's y u get less power case there isnt enough left over to burn all the A/Fhope this helpsmikeGreat write upWould the plugs work just as well in a N/A motor ? Link to comment https://www.fordxr6turbo.com/forum/topic/48973-mikes-step-by-step-guide-to-replacing-spark-plugs/page/4/#findComment-813963 Share on other sites More sharing options...
bdave351 Member 81 Member For: 18y 3m Gender: Male Posted 31/01/09 08:28 AM Share Posted 31/01/09 08:28 AM Props to mike for the right up, just changed to the iridiums using your easy step by step guide!Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/48973-mikes-step-by-step-guide-to-replacing-spark-plugs/page/4/#findComment-813973 Share on other sites More sharing options...
Mike XR6T iTs alL DaRDy........ Donating Members 780 Member For: 17y 9m 29d Gender: Male Location: Adelaide Posted 31/01/09 10:27 AM Author Share Posted 31/01/09 10:27 AM Great write upWould the plugs work just as well in a N/A motor ?grahamI doubt u would notice any differance in the NA enginesorry mate, just get some good quality standardsI.e Bosch Platniums or NGK equivilant mike Link to comment https://www.fordxr6turbo.com/forum/topic/48973-mikes-step-by-step-guide-to-replacing-spark-plugs/page/4/#findComment-814040 Share on other sites More sharing options...
Woody3107 Member 8 Member For: 16y 9m 12d Gender: Male Location: Canberra Posted 06/02/09 04:05 AM Share Posted 06/02/09 04:05 AM Thanks Mike,saved me alot of time and money,Owe ya a few beers,Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/48973-mikes-step-by-step-guide-to-replacing-spark-plugs/page/4/#findComment-818065 Share on other sites More sharing options...
seduced Need more power. Now taking donations. Member 753 Member For: 16y 4m 7d Gender: Male Posted 10/03/09 01:21 AM Share Posted 10/03/09 01:21 AM So, how long will these plugs last? As long as the standard ones? Link to comment https://www.fordxr6turbo.com/forum/topic/48973-mikes-step-by-step-guide-to-replacing-spark-plugs/page/4/#findComment-838888 Share on other sites More sharing options...
