Au Xr6 To Ba Xr6t Engine Swap
jAz3
  • Member For: 16y 6m 5d
Hi Guys,
This is my first post in the forums. I am looking to buy an AU XR6 and doing the BA XR6 T engine swap. Has anyone done it ( I did search for about an hour on here and couldnt find anything), I am only looking to swap the engine not trans etc. However my question is, as far as the electrical and ECU side of things, can you use the AU loom and ECU (obviously with a flash) or do you have to swap ECU's and Looms.
Any help would be greatly appreciated.
Kind Regards
Jaze
If this is in the wrong section for questions of this nature, please tell me and I will ask a Moderator to move it.
Thanks again.
  • RUS531
  • Member For: 18y 6m 4d
Gday mate and welcome!
I cant speak about the mechanical side, the loom I will be very different to your AU engine, for example you have boost sensors dual variable cams and individual coil packs just to name a few. and the ecu will be different as well with out a doubt. I could be wrong so feel free to correct me
You are better off buying a engine complete with the harness and ecu, its easier and you won't be giving yourself a big headache.
Cheers
  • Member For: 18y 9m 4d
Make some measurments first mate, the bonnet may not clear the motor... dont know about AU's, but BA motor into EF needs a hole in the bonnet ;)
Cheers
Thanks mate, I will look into it. Theres turbo kits for AU's for about 3k starting price, I might look a bit more into that maybe??
Will do mate, thank you for the heads up.
Any other suggestions would be greatly appreciated, thank you guys once again for your prompt replies.
  • BOOST
  • Moderating Team
  • Member For: 21y 5m 18d
It will be cool if you can do it. You might wanna keep the turbo gear box as it should be stronger than an AU one
  • Member For: 17y 2m 14d
no need for a flash tuner as you wont be able to yse the ba computer as it requires the bcm to allow it to work. You will have to use an autronics or other after market computer to run it and the boost control. You can just buy a ba and fit the motor for the same sort of cost.
