hanra Into the laaaake Member 1,532 Member For: 17y 6m 25d Gender: Male Location: Nrth Qld Posted 18/08/08 09:10 PM Share Posted 18/08/08 09:10 PM If you have to cut the old fitting off, how do you get the new fitting on? Or does the pipe just click into place with it? Link to comment Share on other sites More sharing options...
hqracer89 Donating Members 324 Member For: 17y 6m Gender: Male Location: Ballarat Posted 18/08/08 10:53 PM Share Posted 18/08/08 10:53 PM You screw the in fitting into the power steering pump. Than the pipe get pushed into the fitting. I did this last night. But because I am a retarted and cut the pipe it didnt seal. When cutting the fitting off, cut at the base of the stepped section. This will cut just above the copper clip that holds the fitting in place. The top of the fitting should come off the top. Than you'll need to push the bottom section down. Than remove the copper clip. Now the fitting is off. Check the pipe for damage. Than reinstall the new fitting. Easy as if your not a retard like me. Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 6m 25d Gender: Male Location: Nrth Qld Posted 19/08/08 12:08 AM Share Posted 19/08/08 12:08 AM So how are you going to fix yours? Replace the entire hose? Link to comment Share on other sites More sharing options...
hqracer89 Donating Members 324 Member For: 17y 6m Gender: Male Location: Ballarat Posted 19/08/08 12:29 AM Share Posted 19/08/08 12:29 AM By the looks of it, yeah. I could just patch it up. But I dont wont it to leak again. You'll be right with yours just dont go up and down the fitting. Just cut in along the step section. Link to comment Share on other sites More sharing options...
