  • Member For: 14y 7m 26d
Well at the front if you buy FG falcon camber kits you can actually create more negative camber as they are designed for the falcon not xr's, FPV etc. But then you can also shim it up to reduce camber. I use stock brackets and they are completely shimmed with no more room to go and I have -0.7deg with king sssl springs.
For the rear I would buy the adjustable upper control arms from wholesale suspension! Give you both positive and negative adjustment for the rears which you can do yourself. They're basically like a turnbuckle. But just be aware that to install the left one the diff cradle has to be dropped to undo the inner bolt (and yes this is the only way to do it) so add an extra couple of hundred $$ to the install to have the arms put in but once they're in your sweet.
This is what I'd do based on personal experience with my car
  • I Lead Not Follow...
  • Member For: 13y 1m 26d
^^^ much appreciated buds, I will show my mate this message and go from there..
  • Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds
  • Cruise Control
  • Member For: 14y 7m 25d
there is a page here with no pics of wheel...... im feeling jipped
  • flame magnet
  • Member For: 17y 29d
ok im still awaiting proper fitment on these bloody 22's? I have spoken to a few wheel places and all keep telling me that it will fit (with mods) but cant go any wider then 22x10,still cant provide me with a perfect offset fitment? and what about the fronts?
OHH here is a pic..lol vvvvv
post-50842-0-71414400-1362829163_thumb.j
  • Member For: 17y 11m 22d
Yeah good luck keeping that on the road, you're 2" diameter over the maximum allowed to be fitted to the car legally?
Edited by Full Monty
true dat,,lol plus I seen some guy on the net that if this was an issue nowadays,they make tyre/rim placards from 20" up aswell..
Edited by Dagabond
quote removed,
