bluute Cant wait to drive it Donating Members 884 Member For: 16y 11m 26d Gender: Male Location: Golden Bay,WA Posted 20/12/08 05:09 AM Author Share Posted 20/12/08 05:09 AM looks great mate glad it turned out well looks so much better than the clear after market jobs too you can get away with another coat or two on the sedans as the ute lights are black inside not chrome which makes them a little brighter Link to comment https://www.fordxr6turbo.com/forum/topic/48267-tinting-tail-lights-revisited/page/6/#findComment-789468 Share on other sites More sharing options...
bluey1 Member 68 Member For: 16y 7m 23d Gender: Male Location: Melbourne Posted 19/04/09 07:53 AM Share Posted 19/04/09 07:53 AM Can this night shade stuff be removed at all? I tried this today and I must admit it was a massive failure. Geting the lens off was impossible without craking bits off. when it finally came off with a bit off force and it came time to spray the first coat, it streaked a fair bit which I stupidly tried to correct only to make it worse. if I go dark enough will the streaky-ness disappear or is it better to just remove it all and start again? assuming it can be removed... Link to comment https://www.fordxr6turbo.com/forum/topic/48267-tinting-tail-lights-revisited/page/6/#findComment-863282 Share on other sites More sharing options...
bluute Cant wait to drive it Donating Members 884 Member For: 16y 11m 26d Gender: Male Location: Golden Bay,WA Posted 19/04/09 10:31 AM Author Share Posted 19/04/09 10:31 AM Can this night shade stuff be removed at all? I tried this today and I must admit it was a massive failure. Geting the lens off was impossible without craking bits off. when it finally came off with a bit off force and it came time to spray the first coat, it streaked a fair bit which I stupidly tried to correct only to make it worse. if I go dark enough will the streaky-ness disappear or is it better to just remove it all and start again? assuming it can be removed...It can be removed mate same as paint etc.. read the back of the can it has clean-up instructions When you do it you only spray ONE light coat at a time let it touch dry then the next coat it will be impossible to get runs if you do this if the lenses aint coming off easily then turn up the oven temp a little the glue will soften always do it coat by coat putting the lense back on the housing temporarily with tape and slotting it back into the car to check the darkness is advisable too so you get it right the first time Link to comment https://www.fordxr6turbo.com/forum/topic/48267-tinting-tail-lights-revisited/page/6/#findComment-863443 Share on other sites More sharing options...
sixappeal Small Member™ Donating Members 2,015 Member For: 17y 5m 3d Gender: Female Location: Perrrf. WA. Aus. ™ Posted 19/04/09 10:35 AM Share Posted 19/04/09 10:35 AM Looooks mint!! Link to comment https://www.fordxr6turbo.com/forum/topic/48267-tinting-tail-lights-revisited/page/6/#findComment-863453 Share on other sites More sharing options...
ravenhard Donating Members 1,517 Member For: 17y 4m 6d Gender: Male Location: Blacktown! Posted 25/10/09 02:38 AM Share Posted 25/10/09 02:38 AM wow this is such a hard mod to do. I just wrecked a tail light I got by first using too much heat, then applying too much force. Lucky I got this pair of light from ebay for $10 and a 10minute drive. Some hints as I practised on this set before I go a buy another pair of light(if anybody has got some let me know)Firstly take the chrome garnish off before putting it in the oven.I used a stanley knife to "cut" the sealent a few times before prying it off with a flathead. Pry and cut between the red lens and black bit as in photo.Dont put it in the oven like I did for too long. I first put it in for 5 mins on 100C, then when that didnt work I cranked it up to 15C for 15mins. This melted the lens and it sorted melted the lens inwards a bit on the clear bit and red bit so its now concaved(doesnt matter as I broke the lens anyways). Any other hints from people who have done this easily? Link to comment https://www.fordxr6turbo.com/forum/topic/48267-tinting-tail-lights-revisited/page/6/#findComment-946864 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 18y 1m 13d Gender: Male Location: Melbourne Posted 25/10/09 05:14 AM Share Posted 25/10/09 05:14 AM I just cleaned mine and sprayed it straight on, looks dull at first but shined up after about a month. It's doesn't look to glossy either like it can do if you spray the inside. Link to comment https://www.fordxr6turbo.com/forum/topic/48267-tinting-tail-lights-revisited/page/6/#findComment-946898 Share on other sites More sharing options...
KLR250 Member 60 Member For: 15y 2m 24d Posted 21/04/10 01:24 PM Share Posted 21/04/10 01:24 PM I only sprayed mine on the outside,but im not happy with it,but it'll do Link to comment https://www.fordxr6turbo.com/forum/topic/48267-tinting-tail-lights-revisited/page/6/#findComment-1002328 Share on other sites More sharing options...
Anchor Member 270 Member For: 15y 3m 29d Gender: Male Location: Rockhampton Posted 07/07/10 08:43 AM Share Posted 07/07/10 08:43 AM Painter done mine today. Dunno how he done them. They look pretty darn neat up close. Also done the indicators and the reflectors on the rear bar. As well as debadging the whole car. Link to comment https://www.fordxr6turbo.com/forum/topic/48267-tinting-tail-lights-revisited/page/6/#findComment-1022380 Share on other sites More sharing options...
Brad-D Member 29 Member For: 16y 5m 8d Posted 07/07/10 09:37 AM Share Posted 07/07/10 09:37 AM Any1 here been defected for tinted lights?? Link to comment https://www.fordxr6turbo.com/forum/topic/48267-tinting-tail-lights-revisited/page/6/#findComment-1022399 Share on other sites More sharing options...
berzerker Donating Members 767 Member For: 17y 6m 18d Gender: Male Location: Brisbane Posted 07/07/10 02:51 PM Share Posted 07/07/10 02:51 PM Anchor did you spray the inside or outside of the lens? Link to comment https://www.fordxr6turbo.com/forum/topic/48267-tinting-tail-lights-revisited/page/6/#findComment-1022499 Share on other sites More sharing options...
