jason426 Member 9 Member For: 16y 7m 29d Posted 31/07/08 11:43 AM Share Posted 31/07/08 11:43 AM hi got a bosch fuel pump from aps not sure of the best place to put it and do I need a fuel pressure regulator Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m 6d Gender: Male Location: central coast Posted 31/07/08 11:56 AM Share Posted 31/07/08 11:56 AM (edited) normally there an in tank set up unlees your running a surge tankand no to the regulator unless you got some serious mods Edited 31/07/08 11:58 AM by our06t Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 7m 20d Gender: Male Location: Nrth Qld Posted 31/07/08 12:33 PM Share Posted 31/07/08 12:33 PM Ute or sedan? Link to comment Share on other sites More sharing options...
jason426 Member 9 Member For: 16y 7m 29d Posted 02/08/08 04:15 AM Author Share Posted 02/08/08 04:15 AM Ute or sedan?its a sedan Link to comment Share on other sites More sharing options...
rboksic Donating Members 514 Member For: 20y 9m 5d Posted 02/08/08 06:40 AM Share Posted 02/08/08 06:40 AM hi got a bosch fuel pump from aps not sure of the best place to put it and do I need a fuel pressure regulatorIf it's a inline pump close as possible to the fuel tank . Link to comment Share on other sites More sharing options...
MYWPN Donating Members 554 Member For: 19y 7m 2d Gender: Male Location: Bendigo Posted 02/08/08 07:52 AM Share Posted 02/08/08 07:52 AM (edited) If you have an APS external pump and bracket, the best place is to mount in on the LHF rail where the swaybar bolts to the body and you will need to run wiring from the rhf fuse box in engine bay and you wont need a pressure regulator Edited 02/08/08 07:52 AM by MYWPN Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m 6d Gender: Male Location: central coast Posted 02/08/08 11:18 AM Share Posted 02/08/08 11:18 AM this is some thing I dont understand if you fit another fuel pump in the fuel line will it actually draw fuel threw the factory pump if it runs out of volume I would have thought once the factory unit reaches it's limit it would just become a restriction for the other pump trying to supply fuel ,that's one of the reasons we run a surge tank so the factory pump is just supplying an empty tank with no back pressure and the secondry pump can feed off the surge tank and run full pressure to the regulatoreven if it will draw threw the factory pump you will still sufer from the fuel surge issue these tanks have when you run the sort of power that requires a bigger fuel pump Link to comment Share on other sites More sharing options...
jason426 Member 9 Member For: 16y 7m 29d Posted 02/08/08 10:32 PM Author Share Posted 02/08/08 10:32 PM If you have an APS external pump and bracket, the best place is to mount in on the LHF rail where the swaybar bolts to the body and you will need to run wiring from the rhf fuse box in engine bay and you wont need a pressure regulatorthanks for that info but will I need a surge tank and with the fuel line do I cut it and will hose clamps hold the pressure. Will standard injectors be ok till I buy bigger ones Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m 6d Gender: Male Location: central coast Posted 03/08/08 08:11 AM Share Posted 03/08/08 08:11 AM You might want to give us more of idea what you want to do to the car the stock fuel pump is good for 260rwkw or more wich will be the limit of your injectors ,so if you put bigger injectors in at that stage then you will probably want a surge tank in the sedan then run the bigger fuel pump off thattell us what your trying to do at the end of the day ,that might make it easier to help you Link to comment Share on other sites More sharing options...
jason426 Member 9 Member For: 16y 7m 29d Posted 03/08/08 12:02 PM Author Share Posted 03/08/08 12:02 PM I'd like to get 300 rwkw or more. I have a tuner getting 3.5 exhaust on saturday, then I'm going to get injectors & a intercooler. I will then go get it tuned Link to comment Share on other sites More sharing options...
