Fletchus Member 36 Member For: 17y 13d Gender: Male Location: Mandurah W.A Posted 28/07/08 10:49 AM Share Posted 28/07/08 10:49 AM I have spent days reading all the threads on how to install a dvd player im just confirming I can get away with everything only using this kit http://www.asllogistics.com/catalog/Video-conversion-kit-p-19.html ? and everything would be plug and play? sorry if I have got this wrong and sound like an idiot bout this just want to make sure! and when the normal screen is on with the icc and it comes up with Aux on it how does the video come through! Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/48099-just-to-confirm-premium-icc/ Share on other sites More sharing options...
Slammer Member 81 Member For: 18y 2m 9d Gender: Male Location: Motherland Posted 29/07/08 03:45 AM Share Posted 29/07/08 03:45 AM Assuming you have a premo ICC with a colour LCD and an iPod connecter then yes. That kit only converts the Video into the RGB format. The Audio part of the kit is one of two things. One an input plug that merges two RCA into a 3.5mm jack that you can plug into your iPod connector and the second part is the line filter that goes between the deck and the 3.5mm input jack.If you do need the iPod connector then add this to the list. ASL. Just say your from FXR6T.com and he should give you a better price then on the web.Hope this helped Link to comment https://www.fordxr6turbo.com/forum/topic/48099-just-to-confirm-premium-icc/#findComment-711730 Share on other sites More sharing options...
Slammer Member 81 Member For: 18y 2m 9d Gender: Male Location: Motherland Posted 29/07/08 04:59 AM Share Posted 29/07/08 04:59 AM (edited) sorry if half of that doesn’t make sense I wrote that whilst I was a hurry at work. Also for some reason I can edit it. Edited 29/07/08 05:00 AM by Slammer Link to comment https://www.fordxr6turbo.com/forum/topic/48099-just-to-confirm-premium-icc/#findComment-711750 Share on other sites More sharing options...
Fletchus Member 36 Member For: 17y 13d Gender: Male Location: Mandurah W.A Posted 29/07/08 09:40 AM Author Share Posted 29/07/08 09:40 AM Yeh still not sure on how the video comes through the screen though and would it be cheaper to get that ipod connector from ford or ASL? also theres ( I think) a amplified version and one without the amplified one would be better I hope to tackle this next weekend as I should have all the gear :D Link to comment https://www.fordxr6turbo.com/forum/topic/48099-just-to-confirm-premium-icc/#findComment-711910 Share on other sites More sharing options...
sicklaser Member 183 Member For: 18y 9m 9d Location: Mackay QLD Posted 29/07/08 02:38 PM Share Posted 29/07/08 02:38 PM the kit come with everything you need except your dvd player. just get one from autobarn or somewhere like that. or use an Ipod video. The kit also comes with the AUX input lead but its better to buy the amplified one from for for about $120 and put that in. Link to comment https://www.fordxr6turbo.com/forum/topic/48099-just-to-confirm-premium-icc/#findComment-712063 Share on other sites More sharing options...
