Mods Done
antigravity
  • Member For: 18y 4m 6d
Yeah tune box from capa should provide any problems...
You will find that you pick up a bit more power with some simple mods....
The big thing you need to remember is when you go back to stock after having a
tune you need to rev you car a bit more.... lol
The torque you make will be the most impresive thing.. I make 720nm.... love it...
  • Replies 20
  • Member For: 18y 4m 8d
GO TIGERS!!!
sorry wrong forum :crazystuff:
Yeah I really want to chip it... to completely change it from the car I've been driving the past two years. Done a few minor mods, but really want to make the engine sing.
  • Member For: 18y 5m 5d
With a tune comes added boost, which is the key ingredient in making more power.. As senna said wait till you fit the cat and injectors as they WILL need a tune..
  • You are a dead set goose
  • Member For: 19y 1m 27d
How do you know your nm of torque figure? Did you put it on an engine dyno?
  • Cruise Control
  • Member For: 18y 28d
Im pretty much in the same boat too.....
I didnt want to get a custom tune, then start doing more mods and have to take it back and get it redone again ....so I figured Id do what I wanted "then" take it round for a custom tune.
I know I could have gotten a flash tuner and just loaded generic tunes into it but after reading about some of the dramas others have had with these I thought Id wait till I could just get it done properly and save the hassle.
So far I have cut out to centre mufflers and replaced with hotdogs, fitted a Typhoon I/cooler, an engine oil cooler and a Typhoon cold air snorkel......does it feel any different?......dunno, but it feels like it and sounds like it but it could be just me.
I have got a set of 42lb injectors for it but obviously they cant go in till Im ready for the flash tuner.
Im not after top end power....what I want is good usable power and torque down low to keep it drivable you know...
What sort of power figure will we end up with?...who knows..but the guys have told me she should be round 260-270 rwkws with these mods @ 10psi.....I cant wait for this.... :beerchug:
Edited by BionicXR6T
You've done similar to what I've done. Except I've thrown in an aftermarket cooler, replaced the centre muffler with piping only, and have a pod filter in the airbox. I can definitely feel a difference from stock. I'd say you should too.
I'm thinking of getting a flash tuner and running the 8psi and 10psi stock tunes. If I can hear pinging, then I'll put it back to stock. But if there's no pinging, then I can't see any issues...
Have people's engines blown without pinging with the CAPA generic tunes??
  • Mmmmm......BOOST
  • Member For: 17y 8m 29d
I wouldn't really like to run a generic tune with an aftermarket cooler ,at most the 8psi don't push it with the 10psi ,as for pinging it takes a very good ear to pick minor detonation wich can still do damage
  • Member For: 17y 5m 4d
You need to get it tuned as the tuner can also calibrate the gear changes which is more important then getting more power. I went down the path of cooler, airbox and generic tune, which then ended up with a slipping gearbox and a slight power increase over standard. Just save the $$$ pick-up a used flash box and get a custom tune that will include injectors and valve springs.
www.nizpro.com.au need I say more
Edited by XR6Turbo22
  • 2 weeks later...
  • Member For: 16y 5m 16d
your tune you have is it generic or custom?
I dont know who has been feeding alot of people with this generic tunes are nothing but trouble rubbish because my brothers use them with awesome gains and no problems what so ever. it may be a case of people not looking after their cars with the tune loaded. thrashing them unneccecarily ect. and I know plenty of people with them on their turbos without any worries.
