Bluetooth Incomming Call Problem
djkice
  • Member For: 16y 7m 30d
Mine seems to work - just seems to take about 5 - 10 secs for the call to connect from when you hear the first ring tone. I've actually had a couple of callers hang up before the bluetooth connection actually connected.
Once connected no-one has said they can't hear me.
Outgoing calls are fine.
  • Member For: 16y 7m 2d
mine will work fine one day and then barely the next. I have had problems with both incoming and outgoing. usually when u make an outgoing call the music stays on while dialing and then mutes as soon as they pick up but this doesnt always happen. then it tells me the call is over and then it eventually starts to work??? its def. a PITA
  • 1 month later...
  • Inactive Members
  • Member For: 16y 4m 25d
I have a new G6E and also are noticing significant difficulties in ANSWERING incoming calls from a Bluetooth equipped mobile, in my case, a NOKIA 6131.. Significant delays in the call audibly appearing on the car's audio system after pressing the phone button on the steering wheel..
  • Member For: 19y 6m 9d
Yep - I am having similar issues with the bluetooth in my G6ET. The FG bluetooth definetly does not work as seemlessly as the unit they fitted to my 2007 TTG. That one works perfectly !! What have they done to stuff it up I wonder? Hope there is a fix coming soon though.
