Exhaust Note
Vebbers
  • Member For: 16y 8m 3d
Heyy all!!
Once again, thanx for the help regarding the 'cheap' mods.
I wanted to know what to get if all I want is a better sounding exhaust, no performance gain..would a 2.5" CATnack be suitable for a BF XR6? I beleive there is an emissions problem when changing the CAT, is it a problem when only changing the CATback?
Ive ben quoted 450 for Difilippo 2.5" Catback system fully installed (1 yr warranty)
thanx!
vebbers
  • Member For: 16y 8m 16d
a 2.5" cat back wont affect the cat because the system is from the "cat-back" there is no need to change the cat, they are perfectly fine. you will still get a performance gain because you are increasing the flow. if your after a good note, the 2.5" catback would be good, but get a straight through muffler and this will sound better and sportier than a chambered muffler, and just keep the middle muffler. another variable to sound is the thickness of the steel, a thicker steel to me personally sounds better, doesnt sound cheap. also a set of pacemaker 4490 or 4495 extracters would be good and will improve efficiancy and power.
  • Sexy Member
  • Member For: 18y 2m 5d
Hey mate, even buying a XR6T exhaust and running a pod filter makes the car sounds really good at idle, doesnt drone and sounds good when you put the foot down.
  • 4 weeks later...
Hey all,
I went to a few places around the eastern subs in Melbourne and got a few quotes:
1) $780 for a Stainless steel Xforce 2.5" CatBack installed
2) $656 for a Mild Steel Redback 2.5" installed
3) $550 for a Mild Steel Difilippo 2.5" installed
What seems the best and if people who have heard the difference which gives a "meaner" more deeper note?
thanx in advance!
Vebbers
  • Member For: 17y 3d
Hey all,
thanx in advance!
Vebbers
Stainless steel options are best. I have heard good things about the Difilippo systems, so if the budget can stretch get that in the SS setup
  • Azzman
  • Member For: 16y 6m 23d
G'day mate. You can run into problems when changing the CAT on the BF's as they have a downstream O2 Sensor bit I've heard a few people just get a flash tune and they can get rid of the fault. I have a BFMKII N/A and I just took it to exhaust brothers and for $150 they cut out both the mufflers from the cat back and I got them to put a hotdog in there to act as a resonator and create less drone, so I'm left with a straight through system, and its loud!
  • 1 month later...
