Flickering Gauges
  • Member For: 18y 9m 15d
Have my Oze gauges installed by my tuner when he was doing my Plazmaman install.
However the oil temp and pressure both flicker occassionally. Just often enough to be annoying. Mostly noticed when stationary. Boost is rock solid.
They did this before my oil plate arrived and I assumed it was because they wern't connected to the senders yet.
Enough power or an earth problem?
Am going to take it to an auto sparky for the fix. Just need a clue to give him.
Thanks.
  • Here since the start...
  • Member For: 21y 9m 8d
What do you mean they flicker...
Does the power go on and off or is the needle just flickering around?
Not sure how the sandwich plate would effect the earth at the earth is wired. It doesn't run through the sender body.
  • Forged Member
  • Member For: 17y 11m 27d
I remember a thread about this (I think it was by RUS531) and he figured out that the sandwich plate was not a good conductor so he ran a good size earth strap to it - no more problems. I'm not saying that this is the problem, but there is a good chance the earth has something to do with it
Ok.
I have these exact gauges and the earth is wired. It doesn't run though the sender, sandwich plate and engine.
Where have you sourced the power/earth for the gauges from?
Are the 3 gauges hooked up using the jumper looms?
  • Member For: 17y 10m 21d
turn the lights on and see if the light on the gauge flickers when the pointer on the gauge does, if so you have a bad earth for sure.
Does the boost gauge light flicker aswell?
