Ford Flash 1 To Xcal 2
86gav
  • 69 - PSI
  • Member For: 19y 4m
Hey guys,
Just wondering if any of the tuners could tell me, if my car is currently tuned with a 1st gen flash box is it possible to load my tunes onto an Xcal 2 if I buy one? The Xcal 2 looks like the way to go now.
CHeers
Gav
  • Member For: 18y 7m 28d
Yes it is possible to use the same tune, in fact they both are tuned exactly the same way down to the file code/extension.
You will need your tuner to load the tune into the new unit, so make sure they are happy to do this and if so if they will charge you.
Also don't expect the tuner to leave the adjustability features turned on with their custom tune.
I had an add on ebay a while ago offereing trade ups from flash1 to flash 2's.
When the tunes are loaded into it, the tuner can leave adjustability turned on or off.
If they leave it turned on, the owner can then make some adjustments as they go, some of the adjustments are boost, spark and WOT fuel, these are just some basic adjustments, not like the proper tuning stuff but enough for owners to have a play.
But I would suspect that a tuner would not leave adjustability turned on,on a tune that is allready customised as the owner could make it go bad pretty quickly.
Another option would be the tuner only allow adjustability one way, for example add fuel but not remove it, or pull timing rather than add it.
The unit can aslo check and clear some OBD2 codes
And with this unit and the free software from SCT you can data log your car, like a tuner can.
Tune wise, there is no benefit because the same result can be acheived with either unit.
Also the tunes are actually shown on the screen, so no trying to remember which tune is in which slot.
  • 69 - PSI
Thanks rat that's pretty much answerd my question. Not really interested in having the adjustability mainly want it for the data logging.
Cheers
Gav
