stealthxr Donating Members 553 Member For: 18y 9m 15d Gender: Male Location: The Shire Sydney AUS Posted 18/07/08 11:51 PM Share Posted 18/07/08 11:51 PM the tailshaft is the same between NA and turbo 5 speeds ,....the turbo diff is LSD thouall input shafts on turbo t5/na t5 and 6 T56 are the same with fine spline shafts.If upgrading to a t56 you have to change the yoke and crosmember , and as said before wire in the reverse lockout solenoid. Link to comment Share on other sites More sharing options...
murrayallstar Member 71 Member For: 19y 3m Posted 19/07/08 01:26 AM Author Share Posted 19/07/08 01:26 AM Cool Thanks GuysGavin.K do u have a ba na with a t56Also I was getting a little confused with do or dont need tailshaftCan I have a list of what is exactly required so I can approach mal woods or fern tree to supply me with everything neededThanks for info once again Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 6m 27d Gender: Male Location: Victoria Posted 19/07/08 02:19 AM Share Posted 19/07/08 02:19 AM Mal Wood's could tell you everything you need. They've done plenty of T5 to T56 conversions.From what I understand the only difference in the tailshaft is the yoke that slides onto the splines of the gearbox mainshaft. Whether you replace just the yoke or the whole shaft is up to you. Link to comment Share on other sites More sharing options...
badbrad Member 7 Member For: 11y 4m 2d Posted 11/08/14 04:06 AM Share Posted 11/08/14 04:06 AM Any info on this topic or how things went murrayallstar? I have a ba 04 xr6 turbo with a five speed manual that's starting to play up. I will get all the parts and do the conversion myself. Just want to know what's involved and a parts list. cheers fellas. Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 19y 10m 15d Gender: Male Location: In my house Posted 11/08/14 04:33 AM Share Posted 11/08/14 04:33 AM Mal Woods my friend. Link to comment Share on other sites More sharing options...
Boosted_Falcon Member 86 Member For: 12y 3m 24d Gender: Male Posted 11/08/14 10:10 AM Share Posted 11/08/14 10:10 AM Yeh I just got a tr6060 from Mal, very cheap for what u get and turns the car into something completely different to drive. I can list all the sh*t if u want but if you ring Mal he will advise u anyways Link to comment Share on other sites More sharing options...
badbrad Member 7 Member For: 11y 4m 2d Posted 11/08/14 11:36 PM Share Posted 11/08/14 11:36 PM Cheers guys I'll give mal wood a call, also he'll be able to tell me what is needed. Like if I can use the t5 bell housing, for the t56 or tr6060 and how to sought out the the reverse lock out and if I can modify my t5 crossmember to fit the t56 or tr6060 and the extent of modification needed. But I plan on sourcing all the parts myself and doing all the work myself. On a very tight budget and just the kit from mal woods is too pricey, but if I source the parts myself I should be able to do it cheaper. Link to comment Share on other sites More sharing options...
badbrad Member 7 Member For: 11y 4m 2d Posted 11/08/14 11:41 PM Share Posted 11/08/14 11:41 PM Also part numbers and other things and if I could get any with using a Expensive Daewoo specific box and swap parts ect Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 1m 30d Gender: Male Location: Perth Posted 11/08/14 11:52 PM Share Posted 11/08/14 11:52 PM Cheers guys I'll give mal wood a call, also he'll be able to tell me what is needed.Like if I can use the t5 bell housing, for the t56 or tr6060 You can't. T5 bellhousings is integral and supports the input shaft bearingand how to sought out the the reverse lock out Earth the solenoid at the box and tee into the brake pedal switch for the +ve feed when the pedal is depressedand if I can modify my t5 crossmember to fit the t56 or tr6060 and the extent of modification needed. You'll need the T56 cross member. The effort to modify the cross member (being ally) isn't worth the cost. T56 cross members are cheap and easy to come by.But I plan on sourcing all the parts myself and doing all the work myself.On a very tight budget and just the kit from mal woods is too pricey, but if I source the parts myself I should be able to do it cheaper.On a cost to effort ratio Mal's kit's are very good value. Literally everything is included and new parts are used. I wouldn't expect too much help from somebody who has done the R&D and offers a product if you intend to do it yourself.Also part numbers and other things and if I could get any with using a holden specific box and swap parts ectAgain budget build or not the holden box is not worth the effort. The shifter locations are incorrect, input and output shaft are different and the cost to rectify this will soon be higher than a Ford T56 Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 19y 10m 15d Gender: Male Location: In my house Posted 12/08/14 05:38 AM Share Posted 12/08/14 05:38 AM Great info there Ralph. Link to comment Share on other sites More sharing options...
