Front End Noise
IH8TOADS
  • Member For: 19y 7m 25d
I have this terrible front end noise when turning hard left. I have established the following:
- It knocks and grinds and sounds like metal on metal.
- It comes from the front right only.
- It gets worse after the car heats up and have been driving for a while.
- It's not the wheel bearing / hub assembly as I replaced this.
- It didn't do it when I've left it with ford!
I've looked under the car several times and can't seem to work out what it is. I have had a BF dump and a bigger cat fitted and the exhaust does sit very close to the chassis rail but if the exhaust was heating up and rubbing on the chassis rail I don't think this would explain the noises I'm experiencing! There is a small mark where it looks like it touched.
Any ideas people? Engine mount?
Cheers!
  • Hench, but no longer shredded or tanned.
  • Member For: 17y 11m 5d
the dreaded left turning knock from the front right
I get that too.. cant work out what from though
A pebble! Where was the pebble stuck fatz?
Aaron....does your's ever grind? Mine only happens avove say 20 km/hr. Gives me the $hits. Does yours do it when the car heats up?
I'm pretty sure it's not the swaybar, I checked the bolts. Can't be certain though!
Cheers Guys
Cheers Guys
Yeah mate 'm not sure what it is but it doesnt exactly feel too good from where ya sit
  • 3 weeks later...
FYI Aaron.
I think my noise has dissapeared. I had the rear of my exhaust modified and at the same time had the exhaust guy (Exhaust world on Newcastle St) have a look at the dump and how it sits close to the chassis rail. He ended up moving it over and I haven't heard the noise since.
Get under there and see if your dump is close to the rail. Cheers.
