Ninka Donating Members 1,850 Member For: 22y 6m 12d Gender: Male Location: Perth, WA Posted 18/07/08 02:56 PM Share Posted 18/07/08 02:56 PM mate just buy a set of cp pistons and some h-beam rods and your engine builder can easily sort the rest out.The cp pistons come with a spec sheet that tells you everything you and your machinist need to know for a perfect installation.My experience with CP at atomic tolerances is not good, noisy as hell :ifiusethisimafag: I have built a couple of my own engines using Atomic rods and Mahle pistons, paying very close attention to the build tolerances, and though not exactly like stock sounding, they are pretty close. Link to comment https://www.fordxr6turbo.com/forum/topic/47675-forged-engine-components-tolerances/page/2/#findComment-707516 Share on other sites More sharing options...
RDCULS New Member 16 Member For: 17y 10m 13d Posted 18/07/08 04:08 PM Share Posted 18/07/08 04:08 PM Atomic tells me they now supply/use Mahle pistons (no longer CP) & have no more probs with noise.... Link to comment https://www.fordxr6turbo.com/forum/topic/47675-forged-engine-components-tolerances/page/2/#findComment-707531 Share on other sites More sharing options...
strik9 Banned 146 Member For: 18y 1m 27d Gender: Male Location: AUSTRALIA Posted 18/07/08 10:03 PM Share Posted 18/07/08 10:03 PM yeah right, now I just have to go and feed my flying cops. (no offence to poster) I love a good atomic bashing. and so I should after waisting my hard earned money on his junk. that came recommened. Link to comment https://www.fordxr6turbo.com/forum/topic/47675-forged-engine-components-tolerances/page/2/#findComment-707544 Share on other sites More sharing options...
phildub Member 52 Member For: 18y 11m 19d Posted 19/07/08 01:11 AM Share Posted 19/07/08 01:11 AM I would have think that is if you used Atomic parts your result would either be the same or worse than a complete atomic engine. They will give you the specs to use and the result will be the same. It sounds like you should go and get Autotech Engineering or Nizpro to supply you an engine as they seem to have happy customers or you could repeat what other have done and end up with you money in the bin, sounds like Atomic by name Atomic by nature, boom!!! Link to comment https://www.fordxr6turbo.com/forum/topic/47675-forged-engine-components-tolerances/page/2/#findComment-707604 Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 5m 4d Posted 19/07/08 02:15 AM Share Posted 19/07/08 02:15 AM My experience with CP at atomic tolerances is not good, noisy as hell I have built a couple of my own engines using Atomic rods and Mahle pistons, paying very close attention to the build tolerances, and though not exactly like stock sounding, they are pretty close. Ive got an atomic short motor that has only done 15,000km and was replaced due to sick of noise in a mates car. Was planning on using block,crank and rods and getting a descent set of pistons for my car. Are these pistons you use the goods and can this be done. Link to comment https://www.fordxr6turbo.com/forum/topic/47675-forged-engine-components-tolerances/page/2/#findComment-707615 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 28d Gender: Male Location: SW Sydney Posted 19/07/08 02:35 AM Share Posted 19/07/08 02:35 AM I have used the new Mahle pistons in my engine and I'm happy with it, like Ninka said, its not as quiet as stock, but I've heard alot worse forged engines Link to comment https://www.fordxr6turbo.com/forum/topic/47675-forged-engine-components-tolerances/page/2/#findComment-707619 Share on other sites More sharing options...
strik9 Banned 146 Member For: 18y 1m 27d Gender: Male Location: AUSTRALIA Posted 19/07/08 04:05 AM Share Posted 19/07/08 04:05 AM (edited) I would have think that is if you used Atomic parts your result would either be the same or worse than a complete atomic engine. They will give you the specs to use and the result will be the same. It sounds like you should go and get Autotech Engineering or Nizpro to supply you an engine as they seem to have happy customers or you could repeat what other have done and end up with you money in the bin, sounds like Atomic by name Atomic by nature, boom!!! :fear (5): Edited 19/07/08 04:10 AM by strik9 Link to comment https://www.fordxr6turbo.com/forum/topic/47675-forged-engine-components-tolerances/page/2/#findComment-707643 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 3m 5d Gender: Male Posted 19/07/08 01:26 PM Share Posted 19/07/08 01:26 PM Nizpro were using Wiseco pistons a little while back, dont know about now. Just get your machinist to set them to the spec sheet. They are a pretty tight clearance for a forged piston. There were issues with earlier CP pistons. Dont know about nowIf you do your research properly, dont rush it, have a good machinist and the right tools, you will probably do a better job of most workshops out there who have 15y/o apprentices assembling their engines. But if you are a bit of a cluts then get all the good bits and leave it to the pros for assembly. Link to comment https://www.fordxr6turbo.com/forum/topic/47675-forged-engine-components-tolerances/page/2/#findComment-707854 Share on other sites More sharing options...
ETM Member 1,194 Member For: 18y 3m 22d Gender: Male Location: syd south Posted 19/07/08 01:36 PM Share Posted 19/07/08 01:36 PM my cp's arent noisy 1 Link to comment https://www.fordxr6turbo.com/forum/topic/47675-forged-engine-components-tolerances/page/2/#findComment-707863 Share on other sites More sharing options...
phildub Member 52 Member For: 18y 11m 19d Posted 19/07/08 11:04 PM Share Posted 19/07/08 11:04 PM Nizpro were using Wiseco pistons a little while back, dont know about now. Just get your machinist to set them to the spec sheet. They are a pretty tight clearance for a forged piston. There were issues with earlier CP pistons. Dont know about nowIf you do your research properly, dont rush it, have a good machinist and the right tools, you will probably do a better job of most workshops out there who have 15y/o apprentices assembling their engines. But if you are a bit of a cluts then get all the good bits and leave it to the pros for assembly. I though Nizpro designed there own and then get them made, they have never said what they used Link to comment https://www.fordxr6turbo.com/forum/topic/47675-forged-engine-components-tolerances/page/2/#findComment-707895 Share on other sites More sharing options...
