tab Sucker Moderating Team 32,303 Member For: 21y 11d Gender: Male Location: Brisbane Posted 12/07/08 11:17 AM Share Posted 12/07/08 11:17 AM ....and that's also the general consensus amongst owners as well Has certainly worked OK for me :ifiusethisimafag: Link to comment https://www.fordxr6turbo.com/forum/topic/47452-newbie-oil-question/page/2/#findComment-704766 Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 20y 3m 29d Gender: Male Location: In my house Posted 13/07/08 08:40 AM Share Posted 13/07/08 08:40 AM PHANTMXR6 said: Who says 1000kms is too soon to change your oil?Do you do 1000kms on a dyno before changing oil? I don't think so.I'm a mechanic by trade and I feel that the run in process I used plus the 1000kms of driving I did on the initial oil is plenty. I'm still using mineral oil at the moment but I won't hesitate to be putting in fully synthetic when I get to the 5k mark.Ambient temp where I live is generally high 30 degrees low 40's for most of the year and I would feel much more comfortable knowing I've got some added protection from oil breakdown due to high temps by using synthetic.going to a synthetic to early can glass the bores and cause these engines to start using oil.This happend to my Kawasaki ZX636 when the dealer changed it to a full synthetic just after run in.Turned it in to a oilburner from new..Id be leaving it for atleast 10k before running a synthetic. Link to comment https://www.fordxr6turbo.com/forum/topic/47452-newbie-oil-question/page/2/#findComment-705071 Share on other sites More sharing options...
ETM Member 1,194 Member For: 18y 1m 23d Gender: Male Location: syd south Posted 13/07/08 09:01 AM Share Posted 13/07/08 09:01 AM by 5k you have well and truely run it in, synth would not do any harm by this stage.I have just built a new engine, one of many I have built over the years and my run in precedure is as follows.Start up with penrite "running in" oil, do not allow to idle, minimum revs must be 3000rpm to bed in the cam, do this for 20 mins.If dyno tuning run it hard, just dont let them revs fall for 20 mins, fine tuning can be done later.Once the 20 mins is over dyno tune as per normal, give it heaps.Drop the oil after 500klm, change oil filter,clean turbo supply line filter.Replace with more penrite running in oil, run that till 5000klm, absolutely flog the engine especially in the first few hundred klm, babying it is your biggest enemy.When you hit 5000klm drop that oil,change the oil filter and clean the turbo supply filter and replace with the full synthetic oil of your choice.If you follow this your engine will have very good compression and make good power Link to comment https://www.fordxr6turbo.com/forum/topic/47452-newbie-oil-question/page/2/#findComment-705081 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 17d Gender: Male Location: Earth Posted 13/07/08 09:03 AM Share Posted 13/07/08 09:03 AM FPV TRANNY said: going to a synthetic to early can glass the bores and cause these engines to start using oil.This happend to my Kawasaki ZX636 when the dealer changed it to a full synthetic just after run in.Turned it in to a oilburner from new..Id be leaving it for atleast 10k before running a synthetic.I agree with not running a synthetic oil too early, but how can you determine too early?If you drive like a nanna then yes I'd agree, do 10000kms.But, if you run it hard for the first couple of thousand you should be right.Each to their own I guess. Link to comment https://www.fordxr6turbo.com/forum/topic/47452-newbie-oil-question/page/2/#findComment-705082 Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 7m 28d Gender: Male Location: Mildura Posted 13/07/08 10:54 AM Share Posted 13/07/08 10:54 AM ETM said: by 5k you have well and truely run it in, synth would not do any harm by this stage.I have just built a new engine, one of many I have built over the years and my run in precedure is as follows.Start up with penrite "running in" oil, do not allow to idle, minimum revs must be 3000rpm to bed in the cam, do this for 20 mins.If dyno tuning run it hard, just dont let them revs fall for 20 mins, fine tuning can be done later.Once the 20 mins is over dyno tune as per normal, give it heaps.Drop the oil after 500klm, change oil filter,clean turbo supply line filter.Replace with more penrite running in oil, run that till 5000klm, absolutely flog the engine especially in the first few hundred klm, babying it is your biggest enemy.When you hit 5000klm drop that oil,change the oil filter and clean the turbo supply filter and replace with the full synthetic oil of your choice.If you follow this your engine will have very good compression and make good powerLOL..... Link to comment https://www.fordxr6turbo.com/forum/topic/47452-newbie-oil-question/page/2/#findComment-705156 Share on other sites More sharing options...
ETM Member 1,194 Member For: 18y 1m 23d Gender: Male Location: syd south Posted 13/07/08 11:00 AM Share Posted 13/07/08 11:00 AM im serious dingo Link to comment https://www.fordxr6turbo.com/forum/topic/47452-newbie-oil-question/page/2/#findComment-705160 Share on other sites More sharing options...
