  • Member For: 17y 6d
This w/e I am replacing all the factory cold side piping and putting in a new intercooler. I'm also replacing the intake with an under battery intake pipe. Just wondering if I will have to get a tune or whether it will be ok to just drive around for a few weeks until I get a new tune? At the moment I have the 10psi cappa flash tune will it be ok to run still?
  • Member For: 18y 1m 25d
The risk of damage is always on your mind, take it easy untill you get it checked on a dyno.
I would ditch the 10 psi tune in favour of the stock one
  • Mmmmm......BOOST
  • Member For: 18y 10d
yeh with ETM
at least drop back to the 8psi tune or stock if you can put up with it
and don't give it a hard time till it's checked out
  • Member For: 17y 3m 29d
Mate I've dropped back to the 8psi tune running rapids high flow v3.5 (4in intake, cooler hot & cold sides) and im just cruising around, no more than half throttle and taking it real easy untill I get the tune done.
Should be fine if you take it easy mate.
Ok thanks. Anyone recommend any tuners around Brisbane / Ipswich? Was thinking of trying APC at underwood because my bro uses them allot with his evo and seems to be happy with them. If I get a tune I’m going to have to replace my injectors aswell to handle the extra power. Any idea on how much it would cost for a tune and injectors?
  • Sucker
  • Moderating Team
  • Member For: 21y 13d
Look for one that has the runs on the board with these things though, there are allot of OK tuners around the place that will give you a cheap tune....and you get what you pay for
Elite Automotive are at Archerfield and have one of the best reputations around, pitty the owner of the joint is such a bastard though! :blink: Paul is a member on here, don't tell him I sent you or he'll charge extra.
Paul@eliteauto
  • Member For: 17y 7m 28d
Hey Coley,I live out ipswich way, a little further infact, and I drive in to archerfield to see Paul at elite also. He gets my vote.
Not sure about the injector price but tunes start about $895 I think.
