Fitting Sub Box
MICKAJ
  • Member For: 16y 11m 19d
Want to put my sub box into this car, previous cars I've never bothered fixing it down, the carpet has usually just held it roughly in place with friction. But I wanna do this car properly so my question is:
How do I put my MDF box in the car securely and preferably without doing any permananent damage.
  • Member For: 19y 3m 10d
VELCRO IS THE ONLY WAY ! MAKE SURE U USE THE RIGHT SIDE OF THE VELCRO
WORKS A TREAT WHENEVER I HAVE USED IT AND I DRIVE MY CARS PRETTY WILD AT TIMES
  • Member For: 21y 5m 10d
For a more permanent fix you can also remove the sub from the box and drill 2 long self taper screws through the inside of the box into the floor.
This will slow down thieves and in an accident it wont be a problem.
Make sure there is no lines or fuel tank!
Well velcro seems to be the way to go. Don't wanna drill holes because it only leads to more problems of some kind.
Do you guys have a problem with carpet getting pulled every which way in your cars? Do you buy both sides of the velcro or does a particular side stick naturally to the boot carpet?
How did you stick your velcro to the carpet in the car?
Cheers guys
Cheers guys
either sew the velcro to the carpet
most wont sell just one side
u need the grip side not the fluffy side
or self adhesive velcro dots or strips
  • Member For: 21y 3m 7d
  • Gender: Not Telling
my sub box is jammed in just behind the seats with no velcro or anything.. 4 months and many wild nights later and it still hasn't budged.
  • 3 weeks later...
  • Member For: 16y 7m 15d
if you really want to hold the box in place, why not remove the carpet, Sikaflex a piece of 18mm MDF to the floor, put carpet back in then affix the box with some 'L' brackets. no permanent mods to the car but wont let the box go anywhere! Only a thought but it seems to work well for me.
