Dannopower Donating Members 421 Member For: 20y Gender: Male Location: Canberra ACT Posted 30/06/08 03:14 AM Share Posted 30/06/08 03:14 AM Hi Guys,Just wondering, why did the BA GT's come out with a different offset for the rear and front? I think it may have had to do with brake options or something, but im pretty sure the rear rims will fit on the front of any sedan or ute provided they dont have a 6 piston front brake?Can anyone clarify this for me? I think the rears are 28.5mm offset and the fronts are 35mm offset? If they were going on a standards AU or BA is there any reason they wont fit on?Cheers in advance. Link to comment https://www.fordxr6turbo.com/forum/topic/47150-ba-gt-rim-offsets-why-rear-use-only/ Share on other sites More sharing options...
apache_dj Member 145 Member For: 20y 5d Location: Auckland NZ Posted 04/07/08 03:38 AM Share Posted 04/07/08 03:38 AM based on the offsets the 28.5 mm will have 7mm more inside clearance and extend 7mm out further toward the guard. Use the offset calculator below, its really usefulhttp://www.1010tires.com/WheelOffsetCalculator.asp Link to comment https://www.fordxr6turbo.com/forum/topic/47150-ba-gt-rim-offsets-why-rear-use-only/#findComment-701704 Share on other sites More sharing options...
apache_dj Member 145 Member For: 20y 5d Location: Auckland NZ Posted 04/07/08 03:42 AM Share Posted 04/07/08 03:42 AM I think the GT has staggered wheels as well, wider on the back. My car has 9.5" 19s with a 35 offset on the front and it has been challenging to get it to ride without catching the guards and hitting the suspension on the inside as its pretty low. Dan Link to comment https://www.fordxr6turbo.com/forum/topic/47150-ba-gt-rim-offsets-why-rear-use-only/#findComment-701709 Share on other sites More sharing options...
Erko Donating Members 1,079 Member For: 21y 8m 4d Gender: Male Location: Sydney Posted 04/07/08 08:13 AM Share Posted 04/07/08 08:13 AM GTs do not have staggered sizes...they are 8 inch wide all round Link to comment https://www.fordxr6turbo.com/forum/topic/47150-ba-gt-rim-offsets-why-rear-use-only/#findComment-701786 Share on other sites More sharing options...
2MUCHKW Member 350 Member For: 19y 1m 18d Posted 04/07/08 09:22 AM Share Posted 04/07/08 09:22 AM (edited) Dannopower said: Hi Guys,Just wondering, why did the BA GT's come out with a different offset for the rear and front? I think it may have had to do with brake options or something, but im pretty sure the rear rims will fit on the front of any sedan or ute provided they dont have a 6 piston front brake?Can anyone clarify this for me? I think the rears are 28.5mm offset and the fronts are 35mm offset? If they were going on a standards AU or BA is there any reason they wont fit on?Cheers in advance.BF series 1 FPV GT & F6 rear rims had 8mm more offset than the fronts to increase the track slighly at the rear for better handling ... no other reason!The rear rims will rub on the inner guards at full lock if fitted to the front of the vehicle.The spare is a front rim that can be used on the front or the rear in an emergency.Series 2 BF FPV's reverted to the same offset rim all round for ease of tyre rotation and to stop errors when removing and replacing rims. Edited 04/07/08 09:23 AM by 2MUCHKW Link to comment https://www.fordxr6turbo.com/forum/topic/47150-ba-gt-rim-offsets-why-rear-use-only/#findComment-701815 Share on other sites More sharing options...
