80 RPM Member 46 Member For: 17y 3m 15d Posted 30/06/08 03:07 AM Share Posted 30/06/08 03:07 AM Max towing capacity for a 5 or 6spd manual is 1200kg's regardless turbo or N/AMax towing capacity for an auto turbo is 1675kg'sMax towing capacity for an auto N/A is 1675kg's and with the HD kit load levelers and auto transcooler fitted 2300kg'sMax towing capacity for v8's auto's is (with the HD kit) 2300kg's But don't quote me on thatAll the above was resarched when I did my tow barThe guy at ford didn't even know about the 1200kg's max on the manual cog swaper!I wanted to pull my car on a trailer and was dumb founded to find that I could only tow 1200kg's(Manual 5 speeder N/A)doing it with a turbo falcon will depend on your weight of a trailer+carMost car trailers are around 550-650kg's so it would have to be a light carand yes it would void your warrantyif it was drive train related and you had a tow bar capable of towing 2300kg's they'd not give you the benifit of the doubtjust to add I sat my next door neigbours empty car trailer on the back of my ute and it went along way down!One thinks you would need to upgrade the springs to take the extra weight Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 10m Gender: Male Location: Brisbane Posted 30/06/08 03:19 AM Share Posted 30/06/08 03:19 AM Would the towball weight change much between a laden and empty car trailer though? Link to comment Share on other sites More sharing options...
80 RPM Member 46 Member For: 17y 3m 15d Posted 30/06/08 06:00 AM Share Posted 30/06/08 06:00 AM I asked this question myself Assuming that it is geometricly correct then really it should near balance itself when ladenand really more than 150kg down on the ball (in a normal 50mm ball) towing setup is at the upper end of the scaleI don't think this trailer was at all correct but even the ones you hire are quite heavy (but they have to withstand the idiot factor!)and to put it in a different perspective if it was unladen it should be light forward for the extra weight of the car put on top (assuming its front engined)that way you can trim it by having the car forward or back(again asuming trailer is long enough to do this)I have always towed it with my 4x4's and could balance the 5 on the trailer to the point that you would hardly know its there!I was just really suprised even with a 7x5 box tralier laden it sits down and squatsI probably should have done more research when trying to find a sutible car for what I wanted to do! as towing really wasn't a strong point as I found out! Link to comment Share on other sites More sharing options...
doogs8282 Member 22 Member For: 16y 8m 14d Posted 01/07/08 11:22 AM Author Share Posted 01/07/08 11:22 AM I wonder if I got ford to fit the largest reciever hitch suited for my vehicle, if the decided to put the 2300kg tow pack on there, then the warranty responsibility would lie squarely with them? How can ford void their own warranties???Any thoughts on this??I have decided to try and go with the larger one, as that is what the dealership says they fit to most of thier utes.Anyone with a auto turbo ute have a towbar dealer fitted? If so, what rating did you get? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 29d Gender: Male Location: @ my laptop Posted 01/07/08 12:10 PM Share Posted 01/07/08 12:10 PM Don't just assume!Ford says what is and is not covered by the warranty, not the dealer, ford will not warrant any problems caused by a non genuine accessory no matter who fitted it.If you have concerns talk to the dealership, not sales, but the service department and ask them directly about warranty caused by the towing loads you have mentioned. Link to comment Share on other sites More sharing options...
monza1414 Member 58 Member For: 16y 8m 21d Gender: Male Location: Cranny East Posted 01/07/08 12:23 PM Share Posted 01/07/08 12:23 PM I wonder if I got ford to fit the largest reciever hitch suited for my vehicle, if the decided to put the 2300kg tow pack on there, then the warranty responsibility would lie squarely with them? How can ford void their own warranties???Any thoughts on this??I have decided to try and go with the larger one, as that is what the dealership says they fit to most of thier utes.Anyone with a auto turbo ute have a towbar dealer fitted? If so, what rating did you get?this cant be a serious queston surely?? Im quite sure you dealer isnt stupid enough to put the wrong towbar on there to void their own warranty mate Link to comment Share on other sites More sharing options...
doogs8282 Member 22 Member For: 16y 8m 14d Posted 01/07/08 02:13 PM Author Share Posted 01/07/08 02:13 PM If I wasn't serious, I wouldn't be asking for peoples opinions...The info I have been getting is only second-hand from the sales guy from holden, where I am buying the ute from, talking to the ford dealer up the road from them. This is where they are getting most of the things fixed before I take delivery.What I am getting at is that I have been told that there is a 1200 and 2300 rated towpack that ford can fit, but the turbo is rated for 1675 in auto form. The ford dealer apparently said that they usually fit the 2300 tow packs to the utes. How many are turbo, I don't know... I only want to make sure I get the largest capacity tow pack that the warranty will allow. Surely if 1675 is stated as max towing capacity for an auto turbo, then they should have the appropriate tow pack to suit.Sorry if I sounded like I was having a lend of you guys, I just want to make sure I do things right, and I am getting conflicting info.I think I will ring my local dealership in the morning, and see exactally where I stand.Thanks for your input guys Link to comment Share on other sites More sharing options...
80 RPM Member 46 Member For: 17y 3m 15d Posted 01/07/08 08:40 PM Share Posted 01/07/08 08:40 PM (edited) What I am getting at is that I have been told that there is a 1200 and 2300 rated towpack that ford can fit, but the turbo is rated for 1675 in auto form. The ford dealer apparently said that they usually fit the 2300 tow packs to the utes. How many are turbo, I don't know... I only want to make sure I get the largest capacity tow pack that the warranty will allow. Surely if 1675 is stated as max towing capacity for an auto turbo, then they should have the appropriate tow pack to suit.Sorry if I sounded like I was having a lend of you guys, I just want to make sure I do things right, and I am getting conflicting info.I think I will ring my local dealership in the morning, and see exactally where I stand.Thanks for your input guysYou have misunderstood fordThere is the 1675 & the 2300 kg tow packsbecause the manual is alot rarer than the auto they wont make a package to suit both only the more prominently needed one.there was (might not be there now) a towing chart on the ford website that I found that listed all this I'll see if I can find itit is stamped on the tounge of the bar all the load variationsAssuming you get the one from fordfurther note if you fit and tow a load not recomended by the manufacture its not just you warranty you might void, have an accident and if your GVM for trailer and load is more than the rating on the bar you'll be in deep 5h!7 ! Edited 01/07/08 08:41 PM by 80 RPM Link to comment Share on other sites More sharing options...
monza1414 Member 58 Member For: 16y 8m 21d Gender: Male Location: Cranny East Posted 02/07/08 01:46 AM Share Posted 02/07/08 01:46 AM Well put 80 RPM Link to comment Share on other sites More sharing options...
80 RPM Member 46 Member For: 17y 3m 15d Posted 02/07/08 02:42 AM Share Posted 02/07/08 02:42 AM Found the thingy on the websitelink to page scroll down about 75% and the towing capacitys are listedhttp://www.ford.com.au/servlet/ContentServ...4&c=DFYPagenote: note 84 is only with load levelers and the trans cooler kit fittedjust for arguments sake the FG turbo manual ute towing capacity has been rasied to 1600kg'smust get a better clutch than the previous onesalso check the bottom of that page linked it has the explinations all thereRegards,Ryno. Link to comment Share on other sites More sharing options...
