  • Member For: 18y 3m 7d
Can't you just use the speaker signal wires that go to the factory amp into a after market amp that has the high voltage speaker inputs.
  • 3 months later...
  • Member For: 13y 4m 29d
Hi Quadie,
I am running a FG with premo sound, considering my options as to go RCA outputs or get a decent line converter, what would you suggest? as you appear to have experience with both options..
ultimately I want to run a boot sub (or 2) and upgrade the factory door speakers, most likely run all this off an aftermarket 4ch amp and a monoblock amp but open to suggestions that would yield good quality results - I am happy with the ICC, as I simply play audio from my iphone anyway
  • Member For: 19y 5m 17d
Mate get your self an alpine pxe-h660 off eBay. For about
300.
This bit of gear is tops bang for buck value
Eq dsp and time correction with an easy to set up package
Comes with a setup cd and mic put the cd in the ICC
Press a button on the remote and it sets itself up for compensating for bass roll off and all
And provides a flat response curve. The u sit the mic in a few different spots and it sets the eq and time correction
Then turn up ya gains and your rocking !
I will be doing an install write up of this unit over the Chrissy break
U can't beat this unit at this price. For features
If money is no object then go for the audioson bit.1
At around 1000 bucks plus install
As this unit requires a real time analyser
And lots of time to setup
But the results are fantastic
But based on the details you have given id say the alpine is the unit for you
As the bit.1 will only sound great when backed by high sq amps and speakers
Hope that helps you.
If u want a cheaper option go the audio control lc6i
I'll have one up for sale soon
  • 2 weeks later...
  • 1 month later...
yeh mate , they a top piece of gear .
I bit the bullet and went up to the pxa-h800
so my 660 is up for grabs
  • 1 month later...
  • 2 weeks later...
