quadie Donating Members 720 Member For: 19y 6m 2d Gender: Male Location: Muswellbrook,NSW Posted 09/12/09 08:50 AM Author Share Posted 09/12/09 08:50 AM hey guys , its been ages since ive been on.Im still awaiting some who has an FG that I can do so I can write the FG guide!(any takers from the newcastle/syd area interested PM me, of cause the mod will be free of charge for u im currenty developing a board that will turn on Amps with the ICC. give me time I have alot of things on the go!where is no dedicated "sub channel" the signal sent the the Factory amp is just the audio output channel with a lowpass filter to filter hi freq. the cut off point is a bit low so I dont recomment using this option.the best solution is to either split the rear channels to the sub amp and user your amp for low pass filterI have used a Pre-amp style EQ between the icc output and the amp input to help with the lower signal level from the ICCI will update as I get more things sorted. ThanksShaun Link to comment https://www.fordxr6turbo.com/forum/topic/47052-adding-rca-pre-outs-to-icc-guide-is-here/page/10/#findComment-961784 Share on other sites More sharing options...
toxik Member 72 Member For: 16y 9d Gender: Male Location: land of palms (west lake macq) Posted 10/12/09 11:50 AM Share Posted 10/12/09 11:50 AM does the bf have rca outputs /inputs with premo sound? Link to comment https://www.fordxr6turbo.com/forum/topic/47052-adding-rca-pre-outs-to-icc-guide-is-here/page/10/#findComment-962167 Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 6m 2d Gender: Male Location: Muswellbrook,NSW Posted 11/12/09 11:06 PM Author Share Posted 11/12/09 11:06 PM there is an aux input to the ICC( with kit from ford/asl)The ICC dosnt have RCAs outputs standard but follow my guide and u can add them! Link to comment https://www.fordxr6turbo.com/forum/topic/47052-adding-rca-pre-outs-to-icc-guide-is-here/page/10/#findComment-962483 Share on other sites More sharing options...
sickd Member 128 Member For: 17y 6m 20d Posted 26/02/10 12:18 PM Share Posted 26/02/10 12:18 PM has anyone figured out how to get a higher voltage out of these outputs ? .5v is low and the amps know it I have 2 high end amps with high rms outputs and I have the gain up as high as it goes and it is not performing half as well as it should or as it did with the lc6, great idea though just be good to get the volts up around 4-5v even 2v if possible to see the difference? Link to comment https://www.fordxr6turbo.com/forum/topic/47052-adding-rca-pre-outs-to-icc-guide-is-here/page/10/#findComment-986001 Share on other sites More sharing options...
sickd Member 128 Member For: 17y 6m 20d Posted 15/03/10 08:30 AM Share Posted 15/03/10 08:30 AM WELL!!!!!!! any of you gurus figured out how to raise the signal voltage from these rca outputs? Link to comment https://www.fordxr6turbo.com/forum/topic/47052-adding-rca-pre-outs-to-icc-guide-is-here/page/10/#findComment-991252 Share on other sites More sharing options...
KeepLeft Member 240 Member For: 15y 10m 5d Gender: Male Posted 15/03/10 03:33 PM Share Posted 15/03/10 03:33 PM Come to Perth and you can do mine! I'm dying for details on this mod. Someone give this guy a car already! On 09/12/2009 at 8:50 AM, quadie said: hey guys , its been ages since ive been on.Im still awaiting some who has an FG that I can do so I can write the FG guide!(any takers from the newcastle/syd area interested PM me, of cause the mod will be free of charge for u im currenty developing a board that will turn on Amps with the ICC. give me time I have alot of things on the go!where is no dedicated "sub channel" the signal sent the the Factory amp is just the audio output channel with a lowpass filter to filter hi freq. the cut off point is a bit low so I dont recomment using this option.the best solution is to either split the rear channels to the sub amp and user your amp for low pass filterI have used a Pre-amp style EQ between the icc output and the amp input to help with the lower signal level from the ICCI will update as I get more things sorted. ThanksShaun Link to comment https://www.fordxr6turbo.com/forum/topic/47052-adding-rca-pre-outs-to-icc-guide-is-here/page/10/#findComment-991422 Share on other sites More sharing options...
sickd Member 128 Member For: 17y 6m 20d Posted 18/03/10 09:40 PM Share Posted 18/03/10 09:40 PM (edited) Edited 18/03/10 09:43 PM by sickd Link to comment https://www.fordxr6turbo.com/forum/topic/47052-adding-rca-pre-outs-to-icc-guide-is-here/page/10/#findComment-992472 Share on other sites More sharing options...
KLR250 Member 60 Member For: 15y 21d Posted 17/04/10 01:50 PM Share Posted 17/04/10 01:50 PM wow,I will definatly be doing this,I never thought it would be so easy Link to comment https://www.fordxr6turbo.com/forum/topic/47052-adding-rca-pre-outs-to-icc-guide-is-here/page/10/#findComment-1001404 Share on other sites More sharing options...
smoke Member 70 Member For: 18y 10m 11d Gender: Male Location: Brisbane Posted 08/05/10 06:59 AM Share Posted 08/05/10 06:59 AM I mainly want a pair of rca's to power a sub... would this be worth it?and can I still run my normal speakers through the factory setup still? Link to comment https://www.fordxr6turbo.com/forum/topic/47052-adding-rca-pre-outs-to-icc-guide-is-here/page/10/#findComment-1005929 Share on other sites More sharing options...
cruze Member 91 Member For: 17y 9m 19d Gender: Male Location: Northshore N.S.W Posted 09/05/10 05:04 AM Share Posted 09/05/10 05:04 AM quadie:I am currently constructing a 2 x 10" sub-box (Kicker C10 Class A-4ohm) + Soundstream Ref300 2-channel amp.Haven't got to the installation yet, as the box is a bit of a grind due to angle and spacing.Would be very keen for your imput on the ICC to Amp power outputs !!!! Link to comment https://www.fordxr6turbo.com/forum/topic/47052-adding-rca-pre-outs-to-icc-guide-is-here/page/10/#findComment-1006165 Share on other sites More sharing options...
