Headsex Donating Members 2,528 Member For: 19y 10m Gender: Male Location: Melb Posted 25/06/08 10:15 AM Author Share Posted 25/06/08 10:15 AM hqracer89 said: Just imagine what its going to be like on Friday night when you break a 9...bwahaha.. run a 9... Link to comment https://www.fordxr6turbo.com/forum/topic/46981-status-on-my-cars-tune/page/11/#findComment-698252 Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 11m 16d Gender: Male Location: south east suburbs Posted 25/06/08 12:07 PM Share Posted 25/06/08 12:07 PM What mods have u done on your car to achieve that power level? Link to comment https://www.fordxr6turbo.com/forum/topic/46981-status-on-my-cars-tune/page/11/#findComment-698341 Share on other sites More sharing options...
xlnt6 Donating Members 350 Member For: 20y 8m 9d Gender: Male Location: Melbourne, Victoria Posted 25/06/08 12:15 PM Share Posted 25/06/08 12:15 PM Danny,How do you get the thing to deliver such boost so low in the rev range ? Your graphs don't show how it builds up, it just starts at about 18psi. I'd figure at 75kmh in third gear the RPM would be around 2000rpm, and I've never seen full boost that low before. What's the trick ?? It is just done with a heap of advance?CheersRobin. Link to comment https://www.fordxr6turbo.com/forum/topic/46981-status-on-my-cars-tune/page/11/#findComment-698348 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 10m Gender: Male Location: Melb Posted 25/06/08 01:33 PM Author Share Posted 25/06/08 01:33 PM Hey RobinMines a auto with a convertor, on the dyno it flashes straight to approx 2800rpm as you can see by the following datalogThe columns are, Time in seconds, Air Temp (degree's F), Desired Boost, Boost error, Engine Load, RPM, Throttle position, Wastegate Duty cycle.As you can see I had load sitting at 2.3ish @ 3600rpm in 3rd gear. Which is fairly typical.One reason why it ramps boost in so hard is because it holds the wastegate shut until the last minute (wastegate duty 1.0 = wastegate shut)This is one of the major benefits of running in closed loop boost control.. The PCM does most of it for you.Although this tune's boost curve does not look perfectly flat on the dyno (it overshoots boost at 3600->3900rpm and then ossilates a little, hense the -2.2 in the boost error being overboost), and then drops off a little. In First gear on the street, it actually needs more duty cycle around that point to bring boost up in first. So coming on boost, it has that extra bit of duty cycle to bring it up in first gear, and when it shifts, the revs only drop to about 4500rpm, where its pretty much running in closed loop to keep it flat.Time (sec) AIR_CHARGE_TEMP BOOST_DESIRED BOOST_ERROR LOAD RPM TP_RELATIVE WASTEGATE_DC72.8 76.5 28.9 0.0 0.76 2280 212 1.0000073.1 76.5 30.6 0.0 0.90 2518 422 1.0000073.5 76.5 32.0 9.6 1.12 2892 570 1.0000073.8 76.4 32.2 15.5 1.39 3082 570 1.0000074.1 76.4 32.9 5.8 1.78 3299 570 0.7703674.4 76.3 34.3 -2.0 2.16 3671 570 0.4975674.8 76.3 35.6 -2.2 2.26 3925 570 0.4775875.1 76.2 35.8 -0.1 2.19 3939 570 0.5023175.4 76.2 35.9 0.4 2.18 3988 570 0.5032775.7 76.1 36.0 0.9 2.20 4047 570 0.5119476.1 76.0 36.0 1.1 2.20 4095 570 0.5309376.4 76.0 36.0 1.0 2.23 4169 570 0.5501876.7 75.9 36.0 0.7 2.25 4268 570 0.5676577.1 75.8 36.0 0.4 2.27 4370 570 0.5847177.4 75.8 36.0 0.7 2.29 4456 571 0.6040977.6 75.9 36.0 0.5 2.32 4547 571 0.6246977.9 75.9 36.0 -0.2 2.35 4631 571 0.6426478.2 76.0 36.0 -0.9 2.38 4718 571 0.6576978.6 76.2 36.0 -1.4 2.39 4798 571 0.6873178.9 76.5 36.0 -1.9 2.39 4878 571 0.7221679.3 76.8 36.0 -2.0 2.40 4980 571 0.7302379.6 77.2 36.1 -1.5 2.38 5101 571 0.7601179.9 77.7 36.3 -0.6 2.34 5197 571 0.8190380.2 78.2 36.5 0.8 2.32 5300 571 0.8586880.5 78.8 36.7 1.4 2.30 5411 571 0.8909380.8 79.8 36.9 0.8 2.30 5480 571 0.9147681.1 80.6 37.1 0.6 2.30 5549 571 0.9184381.5 81.4 37.3 1.0 2.25 5661 571 0.9134581.8 82.7 37.5 0.8 2.22 5779 571 0.9112782.2 83.8 37.7 0.5 2.21 5839 571 0.9010282.5 84.9 37.8 0.0 2.20 5897 571 0.8919082.8 86.1 37.9 -1.0 2.21 5940 285 0.8967383.1 87.2 37.3 -0.6 1.27 5484 0 0.7670383.4 88.9 36.3 0.0 0.28 4597 0 0.58336 Link to comment https://www.fordxr6turbo.com/forum/topic/46981-status-on-my-cars-tune/page/11/#findComment-698379 Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 9m 2d Gender: Male Location: Mildura Posted 25/06/08 03:09 PM Share Posted 25/06/08 03:09 PM lucky I explained all that to you prior to posting hey danny!! Link to comment https://www.fordxr6turbo.com/forum/topic/46981-status-on-my-cars-tune/page/11/#findComment-698406 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 2m 21d Posted 26/06/08 12:18 AM Share Posted 26/06/08 12:18 AM What the interesting part is now how much more duty you had to run to get 18psi compared to 15psi, I recall you telling me that you had it at 0.2 duty or there abouts for most of the way to command 15psi. Although one point to notice is the charge air temps, at the start of the run is 24.7 deg C and at the end of the run its climbed up to just over 30deg C. That is less than a 6 deg increase in charge air temps over a power run at 18psi. More to the point it shows that this power can be made consistently and without stupidly high intake charge temps the motor is far less prone to rod destroying detonation. Link to comment https://www.fordxr6turbo.com/forum/topic/46981-status-on-my-cars-tune/page/11/#findComment-698462 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 22d Gender: Male Location: Sydney NSW Posted 26/06/08 01:26 AM Share Posted 26/06/08 01:26 AM Yeah interesting to see when the turbo goes out of its efficiency range and just starts blowing hot air Link to comment https://www.fordxr6turbo.com/forum/topic/46981-status-on-my-cars-tune/page/11/#findComment-698483 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 10m Gender: Male Location: Melb Posted 26/06/08 09:38 AM Author Share Posted 26/06/08 09:38 AM Fatsex said: What the interesting part is now how much more duty you had to run to get 18psi compared to 15psi, I recall you telling me that you had it at 0.2 duty or there abouts for most of the way to command 15psi.0.2 duty around the 4000rpm-4500rpm mark.. After that it usd to ramp upto approx 0.45 at 5500rpm Link to comment https://www.fordxr6turbo.com/forum/topic/46981-status-on-my-cars-tune/page/11/#findComment-698667 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 10m Gender: Male Location: Melb Posted 26/06/08 09:41 AM Author Share Posted 26/06/08 09:41 AM xr6t_ute said: What mods have u done on your car to achieve that power level?Airbox, Cooler, Plenum, 60lb injectors, Valve springs, 4"dump -> twin 2.5" exhaust, 11.8psi actuator and wastegate port done. Autos been rebuilt with new frictions, and AU planterys with some minor valve body wake up.Other than all that.. she's stock! lol Link to comment https://www.fordxr6turbo.com/forum/topic/46981-status-on-my-cars-tune/page/11/#findComment-698671 Share on other sites More sharing options...
xlnt6 Donating Members 350 Member For: 20y 8m 9d Gender: Male Location: Melbourne, Victoria Posted 26/06/08 10:33 AM Share Posted 26/06/08 10:33 AM Hey Danny what units are the Boost Desired & Error in ?? Link to comment https://www.fordxr6turbo.com/forum/topic/46981-status-on-my-cars-tune/page/11/#findComment-698706 Share on other sites More sharing options...
