Choosing An Engine
Mewk
  • New Member
  • Member For: 16y 8m
Hey Thanks Guys!!!
I finally got in touch with a few wreckers in your country and I have a few prices. I should be making a purchase in the next week or so. The build will be started soon.!!!
I will keep you guys posted............
Thanks again for all the help...
  • Replies 28
  • 6 months later...
  • Forged Member
  • Member For: 18y 12d
Mewk, hows the engine swap going??? I thought it had faded off into the ether, but since you are now looking for a bellhousing you must have the engine in the Mustang right?
  • New Member
Its moving along... slowly.. I should be fitting the transmission as soon as I get a bellhousing..
then I have to rebuild the motor and do the wiring.. still got a good while to go....
ill post up some pics when I get the motor and trans mocked up..
  • 2 weeks later...
  • New Member
I got some pics of the first test fitting...!
looks like it should fit just fine...
I found out though that I will need the rear sump pan off of the new FG in order to clear the steering rack in the front. I should have that next week!..
Found this pic at xtremefordtuning... I hope they dont mind me using it...:
Its sitting a little high in the pic because the front sump is hitting the sway bar and the rack.. Its also causing the motor to be pushed a little to far forward... This should be solved by the new sump...
-Mewk
Edited by Mewk
