F6_Tornado F6+300+ Member 940 Member For: 20y 5m 26d Location: In The Ute Posted 29/06/08 02:57 AM Share Posted 29/06/08 02:57 AM Buf it maybe too late and oil with new filter might be past it. Can you do me a test?Different packs are used in different gears so can you test it and tell me if the problem in when going in and out of 3rd AND does a similar thing in 6th? Before you root it anymore CHANGE the OIL and Filter for Farkkkkkkkkk sake.I posted on here somewhere which packs are used in which gears and if a Pack is gone it will show in more than one gear.The Transmission has a sensor on the input hub and another speed sensor on the output hub and as such knows if a clutch pack is slipping simply by calculating the in and out speeds and matching that to the know gear and as such protects itself from destruction by going to limp mode if this speed is outside the desired target!Lack of oil due to Blocked filter will accelerate the wear and cause your problem. SO CHANGE the bloody filter and oil before its too Late AGAIN!!! Link to comment https://www.fordxr6turbo.com/forum/topic/46942-zf-issue/page/3/#findComment-699744 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 8m 15d Gender: Male Location: Zombie Birdhouse Posted 30/06/08 12:58 AM Author Share Posted 30/06/08 12:58 AM Thanks for the feedback guys. Booked in for tommorrow for oil and filter change. F6 Tornado , thanks for that I will test your theorytommorrow on the freeway. Hopefully it is just a blocked filter. Link to comment https://www.fordxr6turbo.com/forum/topic/46942-zf-issue/page/3/#findComment-700113 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 5m 26d Location: In The Ute Posted 30/06/08 03:12 AM Share Posted 30/06/08 03:12 AM Good luck Buf. Seen quite a few go another run after a Filter and oil change so you might be in luck.Just for the record the Clutches are as follows:Park = DReverse = B & DNeutral = D (same as Park)1st = A & D2nd = A & C3rd = A & B4th = A & E5th = B & E6th = E & CThe most common clutches to wear out are B & E. Link to comment https://www.fordxr6turbo.com/forum/topic/46942-zf-issue/page/3/#findComment-700152 Share on other sites More sharing options...
2MUCHKW Member 350 Member For: 19y 15d Posted 01/07/08 09:08 AM Share Posted 01/07/08 09:08 AM Buf-Phoon said: Thanks for the feedback guys. Booked in for tommorrow for oil and filter change. F6 Tornado , thanks for that I will test your theorytommorrow on the freeway. Hopefully it is just a blocked filter.Whats the verdict? Link to comment https://www.fordxr6turbo.com/forum/topic/46942-zf-issue/page/3/#findComment-700639 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 8m 15d Gender: Male Location: Zombie Birdhouse Posted 03/07/08 12:02 AM Author Share Posted 03/07/08 12:02 AM Update, have driven 300ks with changed pan/filter and oil, all seems to be normal so far. Touches head.Senna ,Ford are farking burglars, parts and oil alone Hope I don't have to do this too often Btw F6_Tornado , there were no issues going in and out of 6th Link to comment https://www.fordxr6turbo.com/forum/topic/46942-zf-issue/page/3/#findComment-701208 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m 27d Gender: Male Location: SW Sydney Posted 03/07/08 12:44 AM Share Posted 03/07/08 12:44 AM If you don't ask you don't get Buf, you should know I'd get you mates rates on the stuff! Hope its fixed btw Link to comment https://www.fordxr6turbo.com/forum/topic/46942-zf-issue/page/3/#findComment-701216 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 5m 26d Location: In The Ute Posted 03/07/08 01:01 AM Share Posted 03/07/08 01:01 AM Buf-Phoon said: Update, have driven 300ks with changed pan/filter and oil, all seems to be normal so far. Touches head.Senna ,Ford are farking burglars, parts and oil alone Hope I don't have to do this too often Btw F6_Tornado , there were no issues going in and out of 6thSounds good Buf!! Please dont tell me you got Ford to do it and they put Genuine ZF oil back in it!! Link to comment https://www.fordxr6turbo.com/forum/topic/46942-zf-issue/page/3/#findComment-701223 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 8m 15d Gender: Male Location: Zombie Birdhouse Posted 03/07/08 05:30 AM Author Share Posted 03/07/08 05:30 AM most certainly not Link to comment https://www.fordxr6turbo.com/forum/topic/46942-zf-issue/page/3/#findComment-701338 Share on other sites More sharing options...
