  • Member For: 19y 4m 24d
I have started fitting my new gauges/tripod to my car and have sold my FPV pod and gauges to a friend. I am wondering if it is ok to remove the whole gauge loom from my car (BF F6) to use in his car (BF 2 XR6T Ute). I cant see any problem using the boost sensor for him but am unsure what issues it may cause by removing the factory oil pressure sender and associated wiring. I am also assuming that after I unplug the loom from my car it should be a straight forward plug in back to his car.
Thanks
Markvan
https://www.fordxr6turbo.com/forum/topic/46760-gauge-wiring-loom/
  • 4 years later...
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 11d
I'm not 100% on this, but I believe the entire loom is transplantable.
The only issue you might have is re-plugging the oil pressure sender hole. This can probably be done with a small part bought from Ford.
