ratter Member 6,793 Member For: 18y 9m 13d Gender: Male Location: @ my laptop Posted 16/06/08 10:46 AM Share Posted 16/06/08 10:46 AM Which is why he has happy customers Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 10m 12d Gender: Male Location: central coast Posted 16/06/08 10:52 AM Share Posted 16/06/08 10:52 AM seems like you got a few yourself mate ,only put your name to a place the other day when someone mentioned it in a post Link to comment Share on other sites More sharing options...
XRPete Member 673 Member For: 17y 6m 2d Gender: Male Location: Here Posted 17/06/08 07:54 AM Author Share Posted 17/06/08 07:54 AM Thanks for the help guys. Mines manual. and if I give it in first, change to second, it just won't rev. Back off or change gears and its good again. I've had it coming off traffic lights without WOT. And it just won't rev.I get the same thing on stock tune when I flash it back, so I'm thinking maybe my problem lies elsewhere???? Link to comment Share on other sites More sharing options...
iTec TEAM BA Donating Members 1,755 Member For: 20y 3m 4d Gender: Male Location: North of The Bridge Posted 17/06/08 08:05 AM Share Posted 17/06/08 08:05 AM XRPeter,you wouldnt happen to have a walbro intank fuel pump would you? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 13d Gender: Male Location: @ my laptop Posted 17/06/08 08:06 AM Share Posted 17/06/08 08:06 AM Thanks for the help guys. Mines manual. and if I give it in first, change to second, it just won't rev. Back off or change gears and its good again. I've had it coming off traffic lights without WOT. And it just won't rev.I get the same thing on stock tune when I flash it back, so I'm thinking maybe my problem lies elsewhere????Manuals do suffer also but not as much as auto's.If yours is doing with the stock tune, you have a problem elsewhere, you need your tuner or mechanic to scan it out and check it over for you. Link to comment Share on other sites More sharing options...
XRPete Member 673 Member For: 17y 6m 2d Gender: Male Location: Here Posted 17/06/08 08:09 AM Author Share Posted 17/06/08 08:09 AM Thanks guys Stock fuel pump.cars booked in but he's real busy can't get in for a month Link to comment Share on other sites More sharing options...
Sasha Member 141 Member For: 17y 7m 4d Gender: Male Location: North Queensland Posted 06/01/09 04:55 AM Share Posted 06/01/09 04:55 AM I have a very similar issue with my 03 manual t ute. On startup, engine stalls, sometimes 3-4 times. Stalls randomly at traffic lights. Idle isnt toooo bad, but a little rough at times. My main concern is that it too seems to suffer from torque control issues, so bad and getting worse weekly. Today taking off from the lights I had to use half throttle, then all of a sudden the throttle would 'catch up' ...It feels like the throttle is OUT OF SYNC with the pedal. A Data log revealed that commanded throttle and actual throttle position were different and gave a code that in reference to the Capa software manual indicated the use of torque control. Why this has only started to happen out of the blue I have no idea. It started off occasionally and only seemed to happen when accelerating hard out of a corner, and on the odd straight. Problem progressively got worse to the stage it would accelerate hard till 5 psi manifold pressure was achieved and then power would drop off as throttle was closed by torque control and revs increased ever so slowly. NOW every day , every drive , 1st -5th, Its a bucket of crap to drive. Going to swap computers with a mate tonight and see if that helps. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 1m 5d Gender: Male Location: SW Sydney Posted 06/01/09 05:13 AM Share Posted 06/01/09 05:13 AM Might seem simple, but have you tried re-setting the throttle? Start the car with your foot flat to the floor (car will not start) and see if that helps. Link to comment Share on other sites More sharing options...
Sasha Member 141 Member For: 17y 7m 4d Gender: Male Location: North Queensland Posted 06/01/09 07:34 AM Share Posted 06/01/09 07:34 AM Yeah its not that, also replaced the plugs, coil packs, throttlebody, fuel pump and filter, new line to fuel pressure regulator, manually checked wastegate not sticking open, boost solenoid lubricated. I am swapping computers with a mate tonight so we will see if that does the trick. Link to comment Share on other sites More sharing options...
Sasha Member 141 Member For: 17y 7m 4d Gender: Male Location: North Queensland Posted 06/01/09 10:31 AM Share Posted 06/01/09 10:31 AM Tried ECU swap with no success, security coding. Neither car started. Link to comment Share on other sites More sharing options...
