DjGsTa Donating Members 944 Member For: 18y 1m 27d Gender: Male Posted 15/06/08 02:33 PM Share Posted 15/06/08 02:33 PM Hey guys.Sorry to make another thread about this bov bs, but I just wanted to ask..I have completely removed the bov off the XR6T. and there is that little gold valve ( forgot what this is called ) letting air out. Is it ok to leave it unblocked or should it get blocked?If so what did you use to block it?This is what my car sounds like with no bov and a pipe I made for it. Thanks for the help. Link to comment https://www.fordxr6turbo.com/forum/topic/46691-question-about-removed-bov/ Share on other sites More sharing options...
ENVY-T CNUTOX Donating Members 3,098 Member For: 22y 5m 2d Gender: Male Location: Not sure? Posted 15/06/08 08:12 PM Share Posted 15/06/08 08:12 PM Put the vacume line back on, grab an 8mm bolt, insert it, then bend the hose and zip tie it. Link to comment https://www.fordxr6turbo.com/forum/topic/46691-question-about-removed-bov/#findComment-693651 Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 6m 9d Gender: Male Location: Melbourne Posted 16/06/08 02:58 AM Share Posted 16/06/08 02:58 AM CORRECT Link to comment https://www.fordxr6turbo.com/forum/topic/46691-question-about-removed-bov/#findComment-693764 Share on other sites More sharing options...
DjGsTa Donating Members 944 Member For: 18y 1m 27d Gender: Male Posted 17/06/08 09:59 AM Author Share Posted 17/06/08 09:59 AM Do I have to block it off? Or is it just an option to do so. Whats the difference of blocking it off? Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/46691-question-about-removed-bov/#findComment-694480 Share on other sites More sharing options...
ENVY-T CNUTOX Donating Members 3,098 Member For: 22y 5m 2d Gender: Male Location: Not sure? Posted 17/06/08 10:35 AM Share Posted 17/06/08 10:35 AM If you don't block it off, you will be sucking in unfiltered air, it is a VACUME line after all. Link to comment https://www.fordxr6turbo.com/forum/topic/46691-question-about-removed-bov/#findComment-694503 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 19d Gender: Male Location: Sydney NSW Posted 17/06/08 11:37 PM Share Posted 17/06/08 11:37 PM Yep it needs to be blocked off, go to an auto shop and grab a block off nipple and a small clamp (or a hose and bolt but it looks dodgy).Not only is it sucking air but also loosting boost, so needs to be blocked. Link to comment https://www.fordxr6turbo.com/forum/topic/46691-question-about-removed-bov/#findComment-694635 Share on other sites More sharing options...
quick xr6 Suspended 229 Member For: 17y 3m 23d Gender: Male Location: sydney Posted 19/06/08 11:08 AM Share Posted 19/06/08 11:08 AM sound sik fill a differents in power? Link to comment https://www.fordxr6turbo.com/forum/topic/46691-question-about-removed-bov/#findComment-695415 Share on other sites More sharing options...
RSK Member 340 Member For: 17y 8m 25d Gender: Male Posted 19/06/08 11:23 AM Share Posted 19/06/08 11:23 AM HM, so you get the DOSE sound from just removing the BOV and plugging the vac line?Or do you need a DOSE pipe? What's a dose pipe? All I've done is put a monza filter on my bov to get a cool pfftchhhhhhhhh sound.....But that's not half bad. Quiet comical Link to comment https://www.fordxr6turbo.com/forum/topic/46691-question-about-removed-bov/#findComment-695438 Share on other sites More sharing options...
sensoryamusia Member 398 Member For: 17y 2m 29d Gender: Male Location: leeming, PERTH Posted 20/06/08 08:43 AM Share Posted 20/06/08 08:43 AM DOSE is the sound it makes with a dose pipe,which is a 90 or 45 degree bent pipe coming straight off the turbo with a pod at the end.FLUTTER is what you get when you just block off the bov Link to comment https://www.fordxr6turbo.com/forum/topic/46691-question-about-removed-bov/#findComment-695827 Share on other sites More sharing options...
SaMmYJ Member 28 Member For: 17y 3m 5d Gender: Male Location: Pascoe vale Posted 22/06/08 11:31 AM Share Posted 22/06/08 11:31 AM sounds tough with this pipe .. also u go slow with it on a hot day ... Link to comment https://www.fordxr6turbo.com/forum/topic/46691-question-about-removed-bov/#findComment-696806 Share on other sites More sharing options...
