walkerstreet Member 27 Member For: 18y 2m 25d Posted 14/06/08 09:31 AM Share Posted 14/06/08 09:31 AM Hi everyone,My BFII XR6 Turbo's been at the dealer for over a week and a half now. They're waiting on a new automatic transmission to come from interstate.It had started to shudder and creak, rocking the whole cabin, at ordinary speeds (anywhere from 20km/hr up to highway speeds). If you changed gears, or accelerated, you'd feel the car rock through the leg that was planted on the throttle. Sometimes there was a crunching sound.I'm not mechanically minded, but is this what they call "driveline shunt"?The mechanics at Ford found water in the ZF 6 speed auto transmission, which had basically stuffed the internals of the transmission. It's been put down as a manufacturing fault (the car is just over a year old) and being fixed under warranty.A friend of mine had the exact same diagnosis for his car (at the same dealer). He has a BF Fairmont Ghia with a ZF 6speed transmission.I've heard of driveline shunt being a problem with BF's and the new FG. Is it the ZF that's at fault? Don't get me wrong, driving with the ZF is the best thing since sliced bread. But could there be a problem with a percentage of them?Penny for your thoughts guys?Thanks .....Walker. Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 11m 7d Gender: Male Location: central coast Posted 14/06/08 09:34 AM Share Posted 14/06/08 09:34 AM did they sat it came from the radiator, the water that is Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 11m 9d Gender: Male Location: Victoria Posted 14/06/08 09:35 AM Share Posted 14/06/08 09:35 AM That is not driveline shunt.Without a doubt your problem has been caused by the trans cooler splitting allowing water into the trans oil. Link to comment Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 17y 9m 21d Gender: Male Location: Nrth Qld Posted 14/06/08 09:35 AM Share Posted 14/06/08 09:35 AM The ol engine full of auto trans and a trans full of water trick ay..... Bugger.... Have they replaced your radiator for you also? Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 11m 7d Gender: Male Location: central coast Posted 14/06/08 09:37 AM Share Posted 14/06/08 09:37 AM it was a problem with some of them having the trans cooler picking up water if the radiator gets a leak ,thought that would have been sorted by the bf2 though Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 11m 9d Gender: Male Location: Victoria Posted 14/06/08 09:38 AM Share Posted 14/06/08 09:38 AM I didn't think the trans cooler for the ZF was setup in the radiator like the 4 speed auto is. Could be wrong? Link to comment Share on other sites More sharing options...
2MUCHKW Member 350 Member For: 18y 11m 16d Posted 14/06/08 10:09 AM Share Posted 14/06/08 10:09 AM Correct ... the trans cooler isnt part of the radiator with the ZF box but instead it utilizes a small compact oil to water heat exchanger at the front of the box on the left hand side. If the heat exchanger core fails coolant simply enters the box ... so despite their small size and high efficency they have one big major disadvantage unfortunately I should replace the heat exchange with an air to oil type on my BF F6 before this happens on mine as this problem has arisen a few times on the forum now and all within the warranty period luckily Link to comment Share on other sites More sharing options...
F6BF Member 438 Member For: 19y 3m 23d Location: Sydney Posted 15/06/08 02:35 AM Share Posted 15/06/08 02:35 AM I should replace the heat exchange with an air to oil type on my BF F6 before this happens on mine as this problem has arisen a few times on the forum now and all within the warranty period luckilyGood point, I will be taking the same approachI think process west was developing a trans cooler for the ZF box. Link to comment Share on other sites More sharing options...
obi Member 150 Member For: 18y 11m 18d Location: Qld Posted 15/06/08 02:49 AM Share Posted 15/06/08 02:49 AM Correct ... the trans cooler isnt part of the radiator with the ZF box but instead it utilizes a small compact oil to water heat exchanger at the front of the box on the left hand side. If the heat exchanger core fails coolant simply enters the box ... so despite their small size and high efficency they have one big major disadvantage unfortunately I should replace the heat exchange with an air to oil type on my BF F6 before this happens on mine as this problem has arisen a few times on the forum now and all within the warranty period luckilyPardon my ignorance, but do you mean a separate transmission cooler ? Link to comment Share on other sites More sharing options...
BALLBREAKER Member 427 Member For: 19y 9m 16d Gender: Male Posted 15/06/08 05:49 AM Share Posted 15/06/08 05:49 AM Anybody know if this has happened to any Typhoons.Its a worry if it moded would FORD still replace it under warranty. Link to comment Share on other sites More sharing options...
